OTTP stage 1 installed
Old 09-04-2010, 06:12 PM
Iam Broke's Avatar
Originally Posted by ronn
Yeah..did you loosen the top passenger side motor mount first? A must do.
Nope, just used a prybar to move things around. Reseated the top mount when I was done though. Got some vibs at idle but not too bad. I need to bump it back up to 900rpm with the lw flywheel anyway. It likes that better.
Old 09-09-2010, 08:06 PM
Iam Broke's Avatar
Wheelhop all gone....
Old 09-24-2010, 08:13 PM
Iam Broke's Avatar
Went ahead and bought the Stage 2 upgrade rear mount. No more vibs than stage 1 and def took some more slop out.
Old 09-24-2010, 09:14 PM
ronn's Avatar
HMM..interesting. I heard stage 2 definitely increases vibes. I guess you're one onf the few to compare both stages. Keep us informed on the vibes..maybe a repost again in a couple weeks?
Old 09-24-2010, 09:58 PM
Pyros777's Avatar
Stage 2 gave me buyers remorse at first. The vibes were enough to make my rear view mirror move on its own, everything rattled, and my wife got nauseous when she rode in it for the first time. lol
Luckily the mounts settled in after putting the car through its paces for about 100 miles or so, and now it is just like stock at idle, with a hint of vibes when I turn the A/C on.
Old 09-24-2010, 10:37 PM
Iam Broke's Avatar
Well, I raised my idle to 900 rpm last winter after putting on the lightweight flywheel so maybe that's the difference. I had the air on tonight and while I did notice it at idle, nothing was drastic. If I bog it a bit on easy takeoff where the rpm drops to around 750 it shakes a bit, but no worse than stage 1 did.
No one else rides in my daily driver so no issues there. I'm pleased with it but I knew what to expect having solid mounts on a '65 Chevelle Malibu SS years ago. (327 c.i., 4 spd)
Old 09-24-2010, 10:51 PM
Pyros777's Avatar
Oh yeah, I should note I idle at 850. That definitely plays a part in the vibes, but overall these mounts are GREAT once "broken in". Highly recommended!
Old 09-26-2010, 02:21 PM
Iam Broke's Avatar
200 mixed miles on the S2, no worries or change. Very pleased.
Old 11-03-2010, 03:13 PM
PenguinPIE's Avatar
for the stage 1 with AC, would the vibs get better over time? I drive with AC on full time and i couldnt stand vibs at all...
Old 11-08-2010, 11:10 PM
05RLS2's Avatar
Did you loosen the top mount and settle everything in before tightening it all down?
I want to do stage 1 also, and like you my AC does get worked and I don't want to deal with an increase in vibrations.
Some mentioned raising the idle, but how bad are the vibrations at stock idle?
Old 11-09-2010, 07:45 AM
  #36
themacguy's Avatar
What are the torque specs of the top passenger side motor mounts?
Old 11-16-2010, 01:57 PM
  #37
themacguy's Avatar
Bump.
I got into the OTTP Stage 1 GB. Anyone know the torque specs for the top passenger side motor mounts?
Old 11-21-2010, 05:47 PM
  #38
395 plus's Avatar
Yes would be nice to get some instructions with the purchase. Hint hint OTTP
Old 11-21-2010, 06:46 PM
  #39
ronn's Avatar
I don't think torque specs are a big deal here.
Hand tighten with the wrench...then 1/2 turn more...done.
You're looking at around 75 lbs for the tranny mounts...prolly 30 lbs for the motor mounts on the passenger side.
Old 11-23-2010, 10:31 AM
  #40
RoadconeTuning's Avatar
i keep seeing you guys talk about tq steer, i cant say i've ever noticed it... the car has a tendency to want to be a little darty when at WOT but it deff doesnt yank one way or the other... wheel hop is a deff issue tho.
Old 11-26-2010, 08:48 PM
  #41
395 plus's Avatar
I really like the how these even help with shifting its smooth and crisp now!!!!!!!!!!! It took me 35 mins to install just checked how hard the stock mounts were on with a torque wrench and repeated when I tightened everthing up.
Used the "how to" and had no problem getting things to line up or need any glue to hold things. Just car ramps, floor jack, 18mm 15mm and rachet wrench (I cheated and used a air rachet).
05-28-2022 03:47 AM
dennis69
10-20-2015 07:39 AM
justinchinn
10-02-2015 12:18 PM
DocSvensk
09-27-2015 02:24 PM
09-26-2015 06:44 PM
Quick Reply: OTTP stage 1 installed
