View Poll Results: How do you feel about the stock clutch
Clutch is great
107
26.75%
Clutch does great when i drive it properly.
191
47.75%
Clutch doesnt do so great, but i know its my fault
42
10.50%
Clutch is completely at fault. hate it.
60
15.00%
Voters: 400. You may not vote on this poll
Our clutch verdict. Once and for all.
#77
no thats not what im saying. and feel free to check your attitude please.
im saying that the people who arent having clutch problems learned to adapt to how the car needs to be driven. its a very unforgiving clutch we all know that. but if you realise that your car is only doing what you tell it to do, you CAN drive it with plenty of hp/tq with no slip problems at all.
theres probably a percentage who have true clutch issues i know that.
but IMO the majority of the burnt clutches, its just driver error.
#78
ok well that gives it more justice...I rarely ever beat on my car but when i do wanna launch it im affraid all its going to do is slip... And it doesnt slip early it slips in the high rpms
#79
1 Post
#80
its impossible for me to say with that little information.
i havent seen how youve driven for the life of your car,
who knows, maybe you are, or maybe you truely got a bad clutch from the factory.
By making the clutch slip video, and now this poll, im merely trying to point out to people....that
instead of automatically blaming the part, maybe one should look to their own driving habits to see if thats a possible cause.
There have been plenty of people who have PMed me saying i saved their clutch from watching that video.
So im sorry if ive pissed some of you off, but if it helps people to learn, and maybe make some adjustments, then ill take the heat from the pissed off people.
#81
Mine has 12,300 miles on it... with the later half of it being 240-260 hp... no slippage at all from mine!
If you know how to drive it... it will last just fine! PERIOD!
#86
hmmmm so your clutch was crispy done and whos fault would that be? You glazed the **** out of it like i said and you just proved that point.
Learn how to drive the car. Since all cars drive differently you shouldn't have tried to drive it like all you other cars straight outta the box. I can't believe you want us to think the clutch burned itself. Common bro...........
GM recommended I get a performance clutch. They themselves told my service manager that the stock clutch isn't that great. I had a choice, get a new factory clutch completely free, and that be then end of it no more warranty on it or buy a performance clutch and get it installed free by them. I obviously chose the performance clutch. I broke the Spec clutch in for 800 miles. I have been driving it hard for 20K and have no problems. I haven't changed the way I drive the car. I changed the clutch. So that tells me the stocker was trash.
#90
Like I said, even GM seemed to think it was a faulty clutch. You can't try and make me believe that 3 nissans, and countless other older ragged out cars can be dogged to death and never have a clutch problem and a brand new car can't be driven aggressively without slipping. Trust me when I say the Cobalt has never seen the abuse I've dished up to my other cars. Now I understand you think your God and you think you know everything but give me a break.
I would say thats me but mine slips once i put a good number of dig races on it within a certain time limit.
#91
now i'm not saying i'm the greatest driver by any means.. but i had an issue with the clutch not engaging so i would have the pedal smashed to the ground and i would grind the **** out of it.. now it's the opposite problem.. it's not bad on the whole but common stock car with 27K on it should not have major clutch issues.. i'm bringing it into the dealer, if they tell me it's not covered (which they will) time for a hyper single.. anyone have some links to good clutches for the 2.4?
#93
#94
1 Post
THis is the only clutch that has slipped for me in a car period....
Your seemed to be so scared to admit your wrong in most cases that maybe these other poeple could actually out drive you and still have problems with a clutch.
rather your immature in your ways to critisize all who have a clutch problem. makes me laugh.
Edit - K I said what I said above. Start off by kooling my jets say I am frustrated in communicating with you guys. I saw your video. I guess if you never had a problem with your clutch I can see how you might think that this is how people are screwing there clutch. But I dont shift that way. I have told you my habits and I have to tell that is why I am getting pissed a little. your either are not believing me or not reading when I say that I make complete shifts, and my slip problems happen in higher RPM when the torque comes on really hard at 4000 to 4500 RPM and it is second gear. you also have to understand the history with my car. 45,000K on it and it holds on the street. just not at the track. when the power is on and the tires cant slip the clutch does. if I had LSD the problem would be worse. maybe that is why you havent experienced it. Do you rev the car and dump the clutch at the start? I sure dont and I dont think you do.
then it slipped at the track at about 40000K I have 45000K and it holds on the street. guess perhaps my standard of a good clutch and opinion of how good a clutch should be is different from others. Hell I know people who dont know how to drive who cant figure out what a slipping clutch is never mind recognize that their own clutch is slipping. (I can find posts of that).
GUess since you cant tell from what I am saying and my story of my experiences that you dont know enough about clutch and how it would last in the hands of someone who is a bad driver with his clutch. Mine would be toast now. but it is not.
Again mine sliped after shifting to second rpms dropped from 5,000PRM in first and was at 3,000. it is clear that it is doing well up to 4500 rpm and then it slips. I have to let off to allow it to catch. instead of a low 14 or a high 13 second run I did 14.5.
TOTALLY NOT HOW I DRIVE MY CAR> and I have explained that.
out of all honesty..ive been driving stick since 12....yes 12,im 21 now, i had no lisence or anything,but learned to drive at that age..and been drivin stick since then...i got the s2 installed and clutch was fine..no slipping,no wear,no nothing...kept doin its job since the day i bout the car...after 17k and 20+ runs at the track,it started slippin just 1st-2nd shift..nothing else...so i still kept drivin how i drove since i got the car...now its slippin 2nd-3rd,and thats when i noticed its not the drivers fault..its just that a stock clutch can hold so much abuse...im not sayin i beat on it ever time i leave my garage...my beatings on the car are mostly highway...60mph+,and downshifts and traffic i get stuck in comin from work,and like i always tell ppl...NOT TWO CARS ARE ALIKE/SAME
I thought the stock clutch was great . I never had any slipping issues with mine , unless I got it too hot at the track . As far as the sensitive herky jerkyness , poly trans mounts in place of the worthless stock ones go a long way . The engagement point of mine was high up on the pedal , which I loved . Ive cut as qwik as 2.0 60's on the stock clutch and radials . Took it out @ 32K miles , as it was just starting to get more sensitive to slipping at the track when it got hot , it was still perfectly fine in 98% of the driving conditions . Unfortunately , I bought a 1st gen Spec 2+ .
That is abuse and bad driving. I have never done that to my clutch. BUt let me tell you a great clutch would be able to handle some of that the odd time and grab completely and hold. the pressure plate is the part at fault. not enough clamping force.
Last edited by Asphalt Assault; 11-11-2007 at 04:18 PM. Reason: Automerged Doublepost
#96
I've drivin a 350Z, Corvette, and a Viper which all have heavy clutches and i must say...that while the cobalt's clutch isnt race ready..i does a fair job at holding the abuse and power that some people put through them. People that complain about too much slip...are driving the car...not wrong but not how the car was designed to be driven. So dont get mad when cobalts dont drive like racecars...because they are far from one.
#97
Mine holds 300 hp on the street just fine, but I don't powershift or launch the car. I have only recently had a problem at the track, and only when trying to get good times out of it. If I try to launch the car hard, like faster than a 2.1 60 ft, then it gets hot and won't hold on the 1-2 shift. Thats on 235/40 KDWs, and with about 40K miles on the stock clutch.
#98
I have 28,000 miles on the stock clutch and it still feels very good! As for modified people, I can't speak for them. The clutch is rock solid when the car is stock and if you can drive!
#100
Coming from owning a 5.0 mustang with a heavy duty clutch...this clutch is shitty. It is way way way to soft. I went from driving my mustang back to my cobalt, and my cobalts clutch felt like i was sitting my foot on a blanket. It needs to be more heavy duty
