View Poll Results: Is your clutch slipping or blown?
Voters: 581. You may not vote on this poll
Pleas every one on this site with an SS S/C READ AND VOTE!
Ok if your clutch started to slip or died when the car was stock or vary close to stock and you dont think it was your falt pleas post and vote.
If it didnt die yet pleas post your mileg and vote!
thanks every one.
later
thanks every one.
later
I have 800 miles Im fair with the stick im not bad. but it will slip from 1st to 2nd when I shift just before redline.
I dont slip it I just dump it from first to second it dosent slip bad just a wee but but it is enuff that im going to replace it with a spec stage 3.
Thanks ever one. so far so good.
Im going to work on geting GM to admit there is a problem and see about geting it fixed.
And if all els fails you atleast have something to show your dealer to prove that your not alon and that the clutch dose fail more then they want to admit to.
later and keep it up guys. And pleas keep it on topic and clean!
Thanks!
Thanks!
only alittle over 1000 miles on my car and ill get it time to time shifting from 1st-2nd and i did get it once from 2nd-3rd. went to the track friday and one run it just slipped the whole way down the track
I voted no . I had 27,000 on mine when it started to show signs of slipping in 1st gear from a dead stop . Im pretty amazed at what my stock clutch put up with . The fact that I only powershift when I drag race and I drag race alot contibuted my early clutch slipping . Had I not done that , the stock clutch in mine woulda lasted ALOT longer . Even at that , when I took my stock clutch out , it didnt look too bad at all .
For those of you having problems, I'm sorry to say I had driven maybe 3 total miles on a stick before I bought this car. Now at 2800 miles, and no problems whatsoever. Maybe I'm a quick learner...
Moderator Alumni
Mine will slip until the car warms up in 1st and sometimes 2nd. Once it's warmed up it holds.
I dunno if it's my 'fault', but I am sure if I drive the car like a grandma the clutch would be fine.
1 Post
Thanks!
Thanks!
1 Post
Bone stock and started slipping at 7000KM. I have 18000K on it now and still with stock clutch. it still slips but I know now more what to do about it. left up quick! it sucks. if the tires have traction and your on the gas it does slip. GM warranty states the clutch is not a warranty item. but if you can convince them the pressure plate is the problem as yours does not have enough spring clamping force (IMO that has to be the difference between guys who experience this problem and not) then you could get it covered under warranty.
I had 12,000 on mine and never an ounce of clutch slippage, it was as crisp when i sold it as it was new. I also did alot of hard fast shifting in it and never a problem.
