View Poll Results: Is your clutch slipping or blown?
Voters: 581. You may not vote on this poll
Pleas every one on this site with an SS S/C READ AND VOTE!
#177
8800 miles on mine and i'm on my third clutch. GM replaced the first one for me and then i said screw it and bought the CM FX400. Now if i can just get it broken in i'de be good to go.
#179
Originally Posted by Fidget
I have been driving standard cars for the past 16 years and i find that the clutch on the ss/sc takes some time getting used to. I stall the car at least once a day. (I have only had the car for 11 days).
#180
i had problems with mine from the first day i got it, brought it to the dealer, they said nothing was wrong. little over 4000 miles the clutch went, ended up buying an after market clutch, dealership installed for free tho. Still 4000 miles on a so called preformance clutch, no excuse!
#181
Well we are almost up to 400 votes now with a stagering 36% fail rate! Thats whay to high even if you cut in half!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
Later
Later
#186
I have 7K on it now and the only time I get any problems is under hard acceleration. I guess it's to the stock clutch and onto a Spec. But I guess the biggest thing I have about the whole deal is that the stock clutch shouldn't slip with the S2.
#187
i never had any problems with it sliping and i do drive pretty hard. i did baby it for the first 2000km or so but after that alot of hard driving, little bit a racing and a few small burnouts. i now have about 14000km on it now, but well see once i get more seroius mods, if it will still hold up.... but i do have plans on putting in a spec stg3+ once i need it.
#188
well I babied the hell outta my car for 11600 miles... never slipped or anything.. then the oher day it just went boom and took out my axle or visa versa... I actually had the dealer accusing me of putting new tires on my car cause they were in perfect shape.. even had the littel nubbies on them still
#191
Originally Posted by BlackSS05
I have 8k on mine and it started back at like 6k. From first to second gear shifts it will sound like it is smoking the tires but just burn the clutch.
#192
I have 1800 miles on my 06 ss s/c. clutch does feel sorta wierd at times only it's after its fully released. i have never felt a clutch slip before so im not positive if thats whats going on. but ill be accelerating from 1800 rpm's or so and around 2100 for example it feels like it stops pulling a little and then starts again.....hmm wish i only knew
#193
have 6,400 miles on my 06 and has been slipping since around 4,000 did not notice it to much untill i got the gm upgrades pulley injecters header and exhaust only been down the track 3 times and was asked by the service guy at the chevy place to run it and tell him what it ran
#194
have 22,000 miles and apparantly according to GM that changing front tires to an all weather tire doesnt make ur clutch slip.....its just blows apart ur transmission (oh, and its not covered under warranty)
#196
spankin new
500 miles on a 2.4 5spd and and the 1-2 shift sounds like a preganant Yak. I do not like the 1-2 slip at all and it has done it since I got it with 6 miles on it. I do not know how to explain it other than that. It is not crisp at all. Maybe after I am done babying it I will notice a difference but at this point I am just monitoring the situation. Prolly just got to get used the clutch, but I thought I could chime in.
#197
just went over 1k on mine. worst clutch i've ever drove in my life. slips 1st to 2nd shift horribly. it takes atleast 4 or 5 secounds for it to finally grab. and slips from take off every now and then
#200
slipping at 4k
had my SS S/C for 6 weeks now, 4k miles and mine is slipping biiiiig time b/t first and second it really sucks.....i've only done two actual burnouts and i dont think that should be enough to kill a brand new clutch. Hopefully i can either get the warranty to cover this or just suck it up and buy a stage 2 or 3.
