please Help ive gone Crazy Hurst shifter install!
OK well its 3am and i'm not done installing the hurst shifter. I seem to be stuck on the last part. I cannot reconnect the right cable to the plastic gray and black things. It seems like the black rubber part of the cable is suppose to go in the hole of the gray and black plastic clips but it doesn't fit in the hole. I try to just clip it but the shifter just moves and does not go in gear. What am i'm suppose to do!!!! Any help please. I'm about to just give up and leave the car with out the shifter because the stock shifter is messed up now.
Hope that helps, kinda hard to tell what the issue is w/o being able to see it...
ok well I finished installing but I guess my hurst shifter did not come with some screw so I went around trying to find one so I tried one but it still wiggles. I got the shifter in but its hard to go into first and second and it wiggles. so im going to call hurst after they are back from vacation about getting a screw.
Delta coupe
09-30-2015 08:11 AM
