Please help, right side popping!?
Ok first off I've looked at the other threads and can't find what i am looking for exactly i saw where they were talking about cv axle and control arms, mine is coming from the front right side of my car, i asked a guy at work and said it might be the axle boot that its cracked or spli, that the boot helps to keep everything lubricated and if it is split or what not it, it does make that popping noise and im ready to fix whatever the problem is. thank you ahead of time for anyone's help
Could you send me the link for what i need I'm sure if i take the tire of i can see if the axle boot is the problem just gotta get to it.. I was think it was the bushing but figured id ask around thank you for your help ill get the tire off thus week, is there a way i can see if its the physically?
No clue i am lowered on eibach sportlines stock struts, its just seems like every time i fix something on my car something else goes wrong i just wanna drive my car with no problems. But welcome to the cobalt world
I home that's what it is, like i said, every tinge i mod my car something else goes wrong i just wish everything would be right for once, thanks yall for the help ill get the passenger side tire of tomorrow or Tuesday and ill post what i see although its pretty much leading to the bushings hopefully
Hopefully the bolt that goes across the sub frame and the control arm is not stuck, mine was stuck and we had to cut it off to change out the bushing... And I feel u I did the clutch at my job and then I seem that bushing was bad so I had to go buy that and the bolt I cut off and now after puttin everything back my tob is mest up so now I'm goin to drop the transmission down for the 3 time
I have the FE1 control arms. Will these not work with my suspension?
When will people learn. Just go Get a 2 ton press and it will save you a lot of time, trouble and probably money. I got mine for $130 and it's already paid for itself after doing my CAB's and my wife's wheel bearings. (Ford Focus wheel bearings have to be pressed into the knuckle)
