Poly Trans mounts?
Poly Trans mounts?
I looking into getting poly filled trans mounts...is it necessary to change out both the front and rear or is changing only the front mount enough to get rid of the excess movement? Looking for opinions....
Can't really answer your question, but I've done both and wheel hop is totally fixed. I'm sure just doing one will change from stock, but both would be better. Honestly, it takes about an hour to take them both out and put the new ones in. Very easy.
1 Post
I did just the front, it killed my wheel hop for sure, but i could not stand the vibrations. I lowered my car so it only created more vibrations.
I eventually took out my mount and i still have no wheel hop for some reason. I guess I come to the conclusion that I've learned how to drive, and my springs helped out a bit too.
n20saturn
09-30-2015 12:26 AM
