Pop out
Old 02-19-2014, 08:32 PM
flaminace's Avatar
im actually looking on their website. they have
05-07 2.2 l61/m86
06-07 2.4 le5/m86
both manual, im assuming the same transmission. and no lsj/mu3's. so nevermind.
Old 02-19-2014, 08:33 PM
kzak104's Avatar
wow, that is a terrible noise.... lol
Xmetalhead2003X's Avatar
Yeah mines 600 grams. Heavy enough to shift effortlessly, or knock someone out haha. Op, hopefully someone with more knowledge will chime in. I want to say f35 is no go, as the SS shifter has reverse lock out and is an 8 bolt crank/flywheel as well as different gearing ratio etc. I don't think the transmission is the issue unless you've toasted 2nd by now.
Old 02-19-2014, 08:38 PM
OP what shifter do you have?
Old 02-19-2014, 08:47 PM
flaminace's Avatar
hopefully. slowbalt, its the ralco rz or whatever. i got it from ebay for the cavalier, and followed the instructions to be able to use it in the cobalt.
Old 02-19-2014, 09:07 PM
The 2.4 and 2.2 use the same f23 transmission, not sure if same ratio but I would assume so
Old 02-19-2014, 10:51 PM
andrewcarr1993's Avatar
Ratio can be slightly different, be sure to check that.
Old 02-20-2014, 07:50 AM
flaminace's Avatar
I'm assuming the 2.4 is slightly shorter?
Old 02-20-2014, 11:12 AM
Try going back to the stock shifter, my brother had that on his cavalier and its just terrible. Have you checked the cables or the clamps yet?
Old 02-20-2014, 06:59 PM
flaminace's Avatar
yes, i've checked pretty much everything that moves from my hand to inside the transmission. its not the shifter, it'll go into gear as long as i dont touch the gas. transmission shop said it might be a bent shift fork? but idk. i dont deal with transmissions. lol
Old 02-20-2014, 07:29 PM
  #36
flaminace's Avatar
how about the f23 from the saturn vue that has a 4.41 final drive? it was bolted up to an l61....
Old 02-20-2014, 08:12 PM
  #37
Yes it'd bolt right up but each gear would be shorter, worse MPG better acceleration. I'll most likely be switching to that or another higher geared F23 with LSD this summer.
Old 02-20-2014, 09:02 PM
  #38
I really wanna use that trans
Old 02-20-2014, 09:36 PM
  #39
YelloEye's Avatar
I sawtoothed my F23's 2nd gear when I had an LT, just ground too many gears and rested my hand on the shifter.
Could downshift and it'd slow, but the second I got on the gas it would pop out. GM replaced under warranty.
Old 02-20-2014, 10:27 PM
  #40
flaminace's Avatar
i honestly could care less about mpg lol.
and yellloeye, thats exactly what mine is doing. would just replacing the 2nd gear fix it? considering it's not under warranty anymore.
Old 02-20-2014, 10:36 PM
  #41
YelloEye's Avatar
I would assume so.
Old 02-20-2014, 11:26 PM
  #42
Would be cheaper to replace the transmission for a new one that just that gear after labor. These transmissions only run $300-400 mileage dependent.
Old 02-21-2014, 08:02 AM
  #43
flaminace's Avatar
I found one with 72k for $320. The vue Trans is $5xx, can't remember exact price.
007Buff
06-11-2017 03:04 PM
10-21-2015 11:57 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: Pop out
