Quaife 6-Speed Conversion for FGP F35 5-Speed Manual Transmission!
Old 08-16-2009 | 02:44 AM
  #151
Sharkey's Avatar
the f23 is a strong tranny, ive seen them reliably behind 550hp, and many more cases behind 400hp. that being said, the f35 has been proven over 400hp without failure. its all in how the car is driven.
Old 08-16-2009 | 02:47 AM
  #152
Maven's Avatar
There is at least one 500+hp F35 car on this site. quite a few 400+hp ones too.
Old 08-16-2009 | 03:53 AM
  #153
jimbos'ss's Avatar
Originally Posted by Maven
Its because theres no reason, the F40 doesnt offer any benefits over the F35 besides one extra gear ratio. Its heavier, not noteworthily stronger, rare, requires fab to install, known to be inferior to other Getrag boxes.
that and iirc there was no LSD for it from the factory like the f35.
Old 08-16-2009 | 09:37 AM
  #154
06G85's Avatar
I would get this JUST so 1st gear doesn't run out in .0000000000000000000000000000001 seconds
Old 08-16-2009 | 01:19 PM
  #155
Maven's Avatar
Then get an SS/TC trans......its a lot cheaper.
Old 08-16-2009 | 06:03 PM
  #156
spike's Avatar
that would be nice....dont you have 2 run ss\tc axels\knuckles and a diff clutch plate for that swap though? i thought i had heard that before,but idk would still be cheaper if so
Old 08-16-2009 | 06:16 PM
  #157
Maven's Avatar
no, not that I nkow of.....you definitely dont need to run LNF clutch i can tell you that.
Old 08-16-2009 | 06:20 PM
  #158
Sizzle06's Avatar
Yeah listen to the gassed up tech beotch,he knows his stuff
Old 10-19-2010 | 04:39 PM
  #159
ben_gary's Avatar
new price $3,237.89
Old 12-16-2010 | 10:42 PM
  #160
Legion's Avatar
Originally Posted by rmbrady
The 6 speed conversion would actually make it a tiny bit worse for highway mileage. It is a close ratio 6 speed, meaning it is better suited for keeping the engine in its powerband for racing. Not at all like the T56 in the corvette which has a deep overdrive for cruising.
Excuse me I have to add this is a really uneducated answer. FOR 3 CLEAR REASONS...
A) The Corvette is Skin Close Ratio Aspect in regards to T-56, which has two variants, both are "close ratio". The .85 is more powerful, the other is the "economic/topspeed" concept.
B) Enless your RPM's go way up or are so low that the car cannot maintain a cruise the fuel economy cannot take a hit.
C) The Close Ratio 6spd, is designed not for "racing" but for the sole purpose of keeping the car capable enough to remove the 5th overdriven type gear (which if anyone pays attention our 5th is not that overdriven) to install 2 shorter gears with a slightly improved top gear (6th) for more TOP SPEED. TOP SPEED = 141mph+ Try it at a track, without a 1.7mile straight I would promise you would be dissapointed if your looking for power.
And where is a bulletproof transmission that'd be more useful, stock ratio's are not that bad.
Don't believe me, call Tremec, or Mercedes who has one of the world's 7+ gearboxes and ask them why they'd do it if it was about the "powerband". If your gear ratio is .65 against 100-250hp your pretty much running 40-70hp to the wheels if your lucky. POWERBAND NUMBERS? Or enhanced engine RPM management for top speed? Because frankly without 400hp I don't see 6th being worth a whole lot of power enless you pulled it after 5th near redline. Seen a 140mph stretch recently? Ganna need one to do that... Just sayin
Old 03-17-2011 | 12:58 AM
  #161
BigBrother's Avatar
Stock Z06's break 160 mph on the back straight at Miller... LOL
+1 to if it were a little cheaper and had a taller 6th for cruising I'd buy it.
Looking into combining parts from other trannies or getting custom gears made in the meantime. This thig would be almost reasonable if it were a full tranny with LSD for that, but just gears and requires install?! No thanks...
Old 03-20-2011 | 09:36 AM
  #162
mongorat427's Avatar
No the end of the axel that goes in the trans is the same spline.
Old 03-20-2011 | 03:56 PM
  #163
Kennyspec's Avatar
no its not. u need the axels from the 2.2 cobalt. the long and short one.
Old 08-10-2011 | 05:24 PM
  #164
speedbugy996's Avatar
Well this looks like it might be worth looking at a lil more. With the Quaife 6speed gear swap and the zzp stage 2 trans with a 4.45 final drive, this would really be a nicely geared transaxle for road racing or time attack without killing the fuel mileage on the street. It may be a bit pricey, but like the man said, "how fast do you wanna go and how much money do you wanna spend?"
Old 12-28-2012 | 09:48 AM
  #165
ryansalazan's Avatar
This is very interesting!
05-28-2022 04:47 AM
HEATON
10-16-2015 08:21 PM
OrangeCoba
10-01-2015 11:00 PM
Iceberg
09-29-2015 01:33 PM
Iceberg
09-28-2015 02:31 PM
