Removing the stock shift knob on a SS
Old 05-15-2005 | 12:21 AM
codyss's Avatar
Mine is not straight on for some reason how do you remove it?
Thanks
Old 05-16-2005 | 04:22 PM
tiny's Avatar
and similarly on a 5 spd ls sport coupe also?
Old 05-17-2005 | 07:20 PM
codyss's Avatar
Well I guess they are pressed on and can be pulled off but it will take a bit of muscles.
Old 05-26-2005 | 06:31 PM
Maven's Avatar
Its not as easy as other knobs unfortunately....Remove the emblem from the top of the shifter knob. Cut away the protector in the center. Mark and drill a 4 mm hole, 5 mm deep into the knob, 3 mm from the edge. The knob can be removed by screwing a self-threading plate screw with a flat tip (25 x 5.5 mm) into the hole.
Remove the shifter knob from the shiftier spline and shifter assembly.
to install:
Apply adhesive to the knob.
Seat the shifter knob over the shifter lever. Ensure the spring and foam rings are correctly seated.
Do not operate the lever until the adhesive(Loctite 292 or similar) has dried (approximately 30 minutes).
Position and fit the emblem over the shifter knob. I dont know why it has such an elaborate shifter...I think the B&M shifter is the way to go...I dont know if its available yet.
Old 07-23-2005 | 02:38 AM
JimmiLS05's Avatar
all that just to change a shift knob... screw that lmao
Old 07-23-2005 | 02:46 AM
zinner's Avatar
Moderator Alumni
Guess I will not be changing the shift knob any time soon
Old 07-23-2005 | 02:48 AM
MarcS's Avatar
The Stig
I was looking at a Hurst T handel shift knob. I suppose I'll be keeping it stock.
Old 07-23-2005 | 01:30 PM
JimmiLS05's Avatar
but a spring for a 5speed shifter?
05-28-2022 04:47 AM
RaginChopsuey
10-27-2015 02:27 PM
10-22-2015 12:57 AM
footballplaya3k
09-30-2015 10:39 PM
2009blackSS
09-30-2015 06:57 PM
