Reverse Motor mounts!!!
Ok guys I want to buy the OTT reverse mounts and I have read a bunch on here- just wanted a straight forward answer - how hard are these things to install? Does it require more than simple hand tools - I do alot of work on my cars myself - got a fully restored 72' camaro and the SS/SC. Just want to make sure that if I buy these things there not gonna make my life a living f'n hell with the install!
Also intersted in the rack spacers. Wanted to know if they are worth it with the reverse mounts and also how tough is the install on those!
Thanks
Thanks
This install is not for the new billet "Rotated" mounts, but the process is the same and its all good. And you really should use a torque wrench to tighten the bolts, 41-46 ft lbs depending on cross bolt or pedestal or trans bolt. Not using a torque wrench leads to posts of " the bolts fell out of my transmission" generally because overtightening rips the threads out. The install is easy to do... The results are excellent... OTTP FTW
ThoR294
10-04-2015 08:44 PM
n20saturn
09-30-2015 12:26 AM
