Reverse Switch
Reverse Switch
Yes I have looked all over before posting and I only find hazy mentions and opinions, but I need to know where the reverse switch is located. My reverse lights went from working sometimes to never. Good bulbs. I used to be able to kick it in and out of reverse a couple times and they would come on. Now I have nothing. 05 5 speed 2.2L. Any help is appreciated.
alright just making sure, u would be surprised at the number of people who post on here first without even doing things like checking there fuses if its electrical our scanning a code if they have a CEL.
all i can tell by what i see on SI. its on the left side of the trans. says to remove the LF wheel. id say go buy one then take off ur wheel and look for it should look just like the new one. pretty easy to install
make sure the reverse switch if plugged in its on the top of the trans near the shifter if you have worked on your car you may have forgotten to plug it in
we had that problem before it burned out completly and we had to take it in to the shop..I know that it is located under the fuse box under the hood and the whole thing has to come out to get to it..
I finally figured it out. The switch is fine, but whatever pushes against the switch is not engaging it. yay. At least I am back to sporadic rather than nothing.
royce777
09-28-2015 07:11 AM
