shifting probs
shifting probs
my car shifts smooth through first, second but hangs up going in to third, but is fine every other gear. I got to pull the shifter back and then push toward third and some times its goes and sometimes it goes into first. My clutch engages perfectly and my transmission does not slip, sputter, or seem to be malfunctioning at all. I had read a while back that there was a shifter pin being replaced, is this the problem i am haveing.
darn not an lnf. i had same issue ended up getting a trans put in. but mine was a grind tring to g in third multiple times with clutch to floor. dealer told me numerous time driver error.
The Rookie24
09-20-2015 04:33 PM
