Short Throw Shifter!!!
This one http://cgi.ebay.com/ebaymotors/00-05...spagenameZWDVW They doen't show the purple so if you want it I would ask for it.
this is the one i bought
http://cgi.ebay.com/ebaymotors/ws/eB...m=170150476051
it didnt show purple either, but now that i see purple im glad it came that way.
i like the shifter its self but i wouldnt want a knob so shiny....cause i dont want the sun beaming off of it into my face ...i like the 8 ball ones though...have you ever seen them ?
#39
#41
yes at the bottom of the sliding piece there are 3 screws that hold the reverse lock out on, just remove them and you dont have to worry about anything. you dont even have to remove the locking pin that holds the sliding piece from coming off.
#42
Haven't you ever seen the pics of the rat driving the hot rod with the 8 ball shifter and flames shooting out of the exhaust? IMO the 8 ball is played out and is just cheap rice.
#46
I feel like that metal knob could get really hot...does it?
and you can leave the RLO on right? are there benefits of taking it off?
#47
RLO is useless to us, but doesn't hurt to leave it on
I haven't had problem with the knob getting to hot, but with the shifter I had in my Cavy it get very cold in the winter. as for removing the RLO, it's a matter of how you want it to look. IMO if you use the knob that comes with the shifter keep the RLO and use it to hold up the boot. If you use another knob remove the RLO.
#48
so my short shifter came in today, it took me a while to figure out to install it, and took a good 2hrs, and im still not done..welli am, but i need to put the center consol back...leme tel u, it was a bitch for me, on the round thing that clips onto the shifter assembly the one you have to tilt and use a screwdriver to push toward the center and pop off, well i broke one of the little clips u needed to push tot he center, woops...and after that it took me forever to relize i had to unclip those 2 plastic things on there, like i read the instruction but it took e awhile ot know what it ment, i didnt know which part was the one i needed to unclip, on the part that stocks out, the part that moves when you go to 1st and second, there was a smaller ball, the stock shifter had a plastic thing covering, do i put that on the short shifter too? or do i leave it like that? cuz i left it like that...what else...well..i cant wait to see the diffrence it makes tommorow, ima go for a lil "cruise"...but one more thing, is it me, or does the stock shifter look alot like the short one? idk? i kinda put them side by side, and they looked relatively the same, hmm, must just be me, then again i had the shift knob on the short one so that coulda been y...
#49
so is this ebay shifter a lot shorter than the stock one? how does it compare to the twm? give me some info, i want to get a short shifter, but i want a good one, so if i can pay 40 bucks as opposed to 140 and get the same performance/quality that would be nice haha
#50
You need to put that plastic cup on your new shifter.
Ebay shifter is good Quality and the throws are shorter than stock, TWM,s throws should be shorter because with the TWM you need to cut the shifter base for clearance.
here's another thread https://www.cobaltss.net/forums/drivetrain-79/will-cosmo-racing-cavalier-short-shifter-fit-2-2-2-4-a-69028/
