ss/tc Clutch and Flywheel in a 06 ss/sc?
Both engines use the same flywheel bolt pattern,transmissions, and tob, so it should be possible right? I know you can't use a ss/tc clutch with a ss/sc flywheel. I searched around but couldn't find a clear answer. Any help would be great! Thanks!
if possible it should work but then again it might not.
p.s. it will work 100%. the lsj upgraded clutch and flywheel is in fact the lnf set up
Last edited by 06SS ALL DAY; 03-17-2011 at 02:43 AM. Reason: Automerged Doublepost
