Tranny drain or fill hole???
the other hole should be right near that one and it looks like the fill hole take the plug out and not much fuild should if it's the fill hole but if it's the drain the it will be running out and the tranny takes saturn fuild
So pretty much you have no idea if that the fill or drain
that's the fill port. If you look at the black frame piece running along the bottom of the picture (it's very over-exposed on the left, and runs acruss the whole bottom of the picture)
In that pic, the drain plug will be behing the frame, right where the axle crosses the frame.
