Tranny fluid
#101
I cant seem to find P/N 88862472 at any of my local dealerships. They say they can order it but it will take 2 weeks and cost $28/quart. Is this the absolute best option for my 08 SS/TC with Limited Slip? I read this entire thread but am still kind of confused. Is the Redline 75W-90NS safe to use? Im guessing Royal Purple Synchromax or any other RP Product would be a no no. I want the absolute best and most recommended stuff. Thank you for any info.
#102
maven when you get the time will it be possible of makin a faq on this because this will be asked over and over again.
ike i recommend oem jm2c.
also people read the thread and then ask the question, maven is sharing information at least take the time to read the thread and see if your question have been answered.
#103
There aren't any compatible fluids with the GM 88862472 fluid specified for the F35 in 08-09 SS/TC. You are better off getting the right stuff and NOT using an aftermarket fluid.
#104
The 08-up fluid(88862472) is very hard to come by, I have been using 21018899 in its place, the newer "72" fluid is slightly thinner than the "99" but I havent heard any complaints from anyone. Ive even had to put the 99 fluid into warranty repair TC transmissions(because the new stuff can take so long to acquire), GM paid for it, so at least some people consider it an acceptable substitute.
#106
This is correct for my 2008 2.2L (5-speed manual), no?
https://www.mobiloil.com/USA-English...on_VI_ATF.aspx
Dexron VI ATF..
Is this what comes stock?
Because my owners manual says Manual Transmission Fluid. GM Part Number: 88861800
Dexron VI ATF..
#113
Maven is this a do-it-yourself type maintenance? Pull the plug, fluid drains by gravity, put the plug back in, and pour the new fluid in until it comes out the fill hole? I heard the dealer charges something like $200 for transmission fluid change, is this true? If so, that does not make sense since they will change the motor oil for $70. I have the F35 transmission in an 08 Cobalt SS with 15,000 miles, never changed the transmission fluid before. I know the fluid lasts a long time, but I want to change it because the car is new and there might be metal shavings in there, peace of mind.
#115
We have a Quaife ATB limited slip. It wasn't really advertised or marketed very well. Ford, OTOH, really milks its advertising for all it is worth with the Focus RS. Quaife ATB? Check. RevoKnuckle? Check. It's basically the same setup as our SS/TC's (Quaife ATB and revised steering knuckles), but with a better interior and about $10k USD more.
They never ran the Focus RS against the SS/TC, but I suspect the SS/TC has the slight advantage due to reduced weight and better agility.The Focus RS couldn't beat a few cars that the SS/TC passed on the track.
#117
can u used the royal purple 75w-90 in a 08 ss/tc becuz i just got a brand new tranny with 0 miles from a 08 and i put it on my lsj and idk if u can used the royal purple
#119
How often are you all changing out the fluid in the MU3s? I know that GM says that it needs no regular changes, I don't believe that. Is 45-50K miles a good time to change it, or should it still have plenty of life left to it?
Also what size allen wrench are you all using on the drain and fill plugs? I have looked at the before, and the drain plug looks really close to the crade. Which works better for this and allen key socket, or just a standard angled allen wrench?
#121
