trans problem
trans problem
I installed a new centerforce clutch and flywheel. after the install the pedal to me was soft but the clutch was bleed a number of times. the veh. now is hard to shift gears. it doesn't grind but it just doesn't seem to want to go. aside from that I broke the clutch in and took the car to the track. my brand new less than 1000 miles clutch slips! I will be calling centerforce because this df series clutch is junk! anyone have an idea as to why the car is now hard to shift and the clutch is slipping.
I have had two Centerforce clutches in other cars and the stock clutch had a harder feel and griped harder than the centerforce. I think the first time it was installed it got some oil on it and glazed but the second one i know was installed right and it slipped also not as bad but it did. so the last 4 trans i did in that car i used stock and had no problems with it. Just the spider gear pin breaking and putting holes in the bellhousing.
