Transmission Rattling
When the car starts there is a rattling noise that lasts for about ten minutes and once the car is warmed up, the noise basically goes away. pressing the clutch in or leaving it out does not make the noise better or worse (not a throw out bearing). any thoughts?
I get a slight rattle from my exhaust for a few seconds on cold starts, but there is a bulletin on the gear rattle. Says its completely normal, should go away when you push in the clutch then rattle again when you let it back out. Vettes do the same thing
