TWM short shifter noise
I just installed my TWM short shifter. I noticed when i shift from 1->2 or 3->4, that there is a snap or a "crunchy" feeling in the shifter. It might be from the little plastic threads on the cables. Is this normal? Because i REALLY dont want to tear all that crap apart again. If it wont hurt anything i'll just deal with it.
THANKS!
THANKS!
sounds like the linkage in the shifter cables may be a little loose, almost, but maybe not quite clipped. you dont have to take the full assembly apart, just take the covers off and check the assembly.
I get the noise, doesn't seems to really affect anything as far as I've noticed. I figured it is a combo of the different bushings and more aggresive shifting that is achieved.
Yeah the plastic piece does need to be cut a certain way. I took the 1 console piece off ( THANK GOD I DIDNT HAVE TO REMOVE EVERYTHING) I saw where it was hitting and i snipped it off.
If you look at the instructions it tells you where to cut ( the picture is showing the underside of the shifter assembly) They also remind you to trim the top, and boy is it a craptacular grainy photo. And of course you dont know exactly where to trim the excess off unless you put the whole thing back on the car. If anyone needs pics i will take some.
Originally Posted by g5mike
Thanks Paul,Ill be putting mine on sometime in the next day or so
Originally Posted by montecarloman
I've noticed when shifting to 4th I get a metallic click. Everythings centered so I havent messed with anything, yet.
I'll see if i can post pics tonight. Its kinda dark out. If not i will tomorrow!
G5mike : No prob
DANRICKARD
10-01-2015 12:08 AM
