upgrading clutch what else needs to be replaced?
ok well i'll be getting an exedy stg 2 clutch soon and i was wondering what needs/should be to be swapped out at the same time i think it's the slave cylinder and TOB but thats it.. also where can i find the part number of the slave cylinder so i can get online
don't neglect your flywheel
I am not sure the part number but get it at gmpartsdirect.com. The best place to get it. Comes to like 82 dollars total after shipping. Also if u are replacing clutch get a flywheel also if u have the cash. Saves on labor if u deside to get one in the future. Try and get the same brand so u know they will work together. If u dont have many miles on your car you can use the original tranny fluid. I only had 18,000 on my car so I reused my fluid. If not get new tranny fluid do not get atf look the gm part number up for the fluid.
I got the exedy stage 2 and the light weight flywheel
A new TOB/slave cylinder (all one part) from ^ listed above
Reused tranny fluid
Thats it !!!
Make sure u bleed the clutch properly and make sure you break it in good b4 u decided to rip on the car!
Good luck
I dont know how much u are paying but my buddy did my whole install in 1 1/2 hours for $200. Gave me a good deal
Reused tranny fluid
Thats it !!!
Good luck
well i have tranny mounts.. so thats not an issue.. i dont want it to rev down faster .. as I have a procharger so it loves higher revs.. however revving up would be nicer.. i dont have the money for a flywheel at the moment though :-(
based on how long it took to install someone i knows hyper single he quoted me 350 for everything ..
