What should I do next?
ok, my car is really pissing me off!
The car won't let me shift into first with out some serious grinding... The car never showed signs until the other day when out of the blue this started happening...
I bled the clutch with the mity vac and I was able to pull out alot of air...
So I went for a drive it is still doing the same thing!
Also, it shifts into all other gears fine, except on occasion it will pop out of second gear by itself after changing into second. (not sure if thats a sign of anything)
I don't think its the clutch it's only 4000mi old after the ordeal with a cm clutch....
I hope its not the 1st and 2nd shift fork...
Anyone have any insight? Any input is appreciated Thanks!!!
I seem to remember a thread about this same issue, but I cant find it.
My car will every now and then feel like it would pop out of second if I didnt have my hand on it.
I dont get any grinding going into first though.
Only 4k miles, take it to the dealer!
Try looking through here:
https://www.cobaltss.net/forums/sear...earchid=821428
I found some that COULD be the same problem.
Either way, good luck!
Originally Posted by Imlikedrpepper
the clutch could just need adjusting, thats what happened to my brothers colorado, and it fixed the problem
