Whats the "I" stand for??
What does the "I" stand for on the shifter. have a 07 g5 gt. but idk if its different then the balts. it goes P>R>N>D>I>L. any ideas? i cant even find it in the manual.
low is for 1st gear
intermediate is for 2nd and 3rd
low is 1st without traction control
intermediate is for hills or something like that
and you could of read the manual rather than ask here and look really stupid
i would tell you what page # but i am to lazy to walk downstairs to my car and look it up
The I stands for Intermediate. It allows the transmission to stay in a certian gear for a longer time or higher RPMs. It also downs shift when going down hills alloying you to use less breaks going down hills. I like useing it in the hills due to the fack that it stays in a gear for a longer time so the tranny doesnt shift as much. Its kinda like a allison trans in the tow haul mode...
"I" is for "spirited driving. It is full automatic but doesn't allow the tranny to shift into Over Drive. The tranny will upshift at higher engine RPMs and will also downshift on its' own as you decelerate. TC does not get turned off -- if you get wheel spin and TC engages you lose power for a few seconds. You can drive in "I" but you lose MPG because the tranny won't go into OD.
"D" is forget-about-it and just drive. Best for MPG as the tranny will upshift to a higher gear quicker and go into OD for the best MPG.
Knowing what your tranny does is important so that you can use it to your full advantage.
Now let those truly ignorant manual drivers start their "if you want to shift you should have gotten a manual" posts
If you want to shift you should have gotten a manual transmission.
When I want to go into 3rd gear i put in 3. when I want to be in 5th gear I put it 5. EASY no alphabet to remember, no algorithms to analyze and keep straight, not wondering if Traction control is on or off.
Sorry, I had to.
Sorry, I had to.
slow-ecotec (06-26-2021)
low is for 1st gear
i really wish i could of got a manual but i got a good deal on my car and it only had 2000 miles on it.
Last edited by justypontiacg5gt; 11-06-2008 at 09:12 PM. Reason: Automerged Doublepost
Sorry, I had to.
Sorry, I had to.
"L" is for off-the-line performance. It turns off the Traction Control (TC), engages the low/reverse band to assist the one-way roller assy through first gear, and holds the tranny in 1st gear until redline and shifts into 2nd gear. Once in 2nd gear you should shift up to "I" before hitting redline.
thank you for telling these people the RIGHT answer... all these stupid answers on here if you dont know what your talking about please dont say it.
nope, its becuase 1 and 2 are misleading.
the tranny in L wILL shift to second eventually and in I the tranny WILL shift to 3rd when u get near redline.
"L" is for off-the-line performance. It turns off the Traction Control (TC), engages the low/reverse band to assist the one-way roller assy through first gear, and holds the tranny in 1st gear until redline and shifts into 2nd gear automatically. Once in 2nd gear you should shift up to "I" before hitting redline.
"I" is for "spirited driving. It is full automatic but doesn't allow the tranny to shift into Over Drive. shifts 1-2-3 and downshifts 3-2-1 The tranny will upshift at higher engine RPMs and will also downshift on its' own as you decelerate. Shifts from 2nd to 3rd at ~4K RPM with part throttle. TC does not get turned off -- if you get wheel spin and TC engages you lose power for a few seconds. You can drive in "I" but you lose MPG because the tranny won't go into OD.
in the cobalt guide the 07 edition i found some of an explanation under automatic transaxle operation page 117
will find the rest later
may be different for the g5
I knew exactly what red07ssna said and could have posted that as well... just chose to be funny so to say that I answered without any idea is for you to say THAT without any idea... obviously, as you were wrong!!
There is a possibility of the tranny going into 3rd gear at redline if you leave it in "L".
I have not done this but I have been PMd by a member who claims his tranny shifts into 3rd with his selector in "L".
Anybody else have this happen when they forgot to shift up to "I" after tranny went into 2nd with selector in "L"?
