Will a 2.0 clutch fit the 2.4?
Just curious if the clutch and flywheel could be swapped form a 2.0 to a 2.4. or is the input shaft in the 2.0 different form the 2.4's thanks
Well i think the tranny itself will bolt up but the clutch won't.
Found it:
The LE5 crankshaft flange has a 6 bolt pattern on the flywheel and the LSJ has a 8 bolt pattern.
Found it:
09-28-2015 12:51 PM
