Dyno Results Dyno pictures, videos and dyno results.
D Rob's 1st Dyno Stock. Numbers inside.
Old 04-01-2011 | 05:59 PM
D_Rob's Avatar
Originally Posted by 08inBama
yeah and i'm pretty pissed.... me and Vince at Trifecta have got to have a coming together.... almost full bolt-on on 23psi:
287whp/321ft-lbs
that is ridiculous
Sorry to hear that. I still don't know how much they should put down. But if it's any condolence, Arthur said his dyno has been constantly called stingy and that it usually reads low. You didn't have a base before this one either did you.?.?
That stinks man.
Old 04-01-2011 | 06:05 PM
08inBama's Avatar
i know a guy who put down 307 on it with just IC piping and a tune.... and i'll leave the rest for the imagination
I have that, a downpipe, an an intake and apparently with a whack ass tune... another thing is Paul and I think his dyno is just all overthe place, guys from HSVracing have complained about this exact thing in the past... kick ass pull one week, not **** the next with the same car
at least it sounded good and i know it runs hard(as witnessed by most of the Bama crew here), so i'm still not complaining:
http://s37.photobucket.com/albums/e7...-22-14_573.mp4
Old 04-01-2011 | 07:02 PM
D_Rob's Avatar
Nice vid. I haven't heard that about them but I'll know soon myself when I go back later this month. I hope it's not all bad, because I don't know of any other place nearby to go and get tuned.
Old 04-08-2011 | 06:56 PM
alleycat58's Avatar
Originally Posted by ronn
" Available as a coupe only, the SS Supercharged featured the 2.0 L LSJ Ecotec engine with an Eaton M62 Roots type supercharger and air-to-liquid intercooler.[2] The engine makes 205 hp (153 kW) at 5600 rpm and 200 lbˇft (271 Nˇm) at 4400 rpm"
Well, something doesn't *compute* given the 195 WTQ. A stock SS/SC has 200Ft Lbs FLYWHEEL torque and that renders 205 FLYWHEEL HP. As you can see, the HP and Torque are almost the same here. Setting aside that your * TO THE WHEEL* #s are greater (?), your HP # still should have been not much greater than 200-205. Did the dyno take you to higher revs than stock..if so where did you peak? (5600RPM is peak on stock). Even then, 225 would be a stretch, given the 195 torque.
Seems completely in line with everything I've ever seen. My baseline dyno was 218whp/187ftlbs.
Old 04-11-2011 | 12:37 PM
soundjunky's Avatar
Ronn;
this is an easy one;
GM fudged the numbers on the SS/SC slightly;
not as blatantly as the Neon SRT4* , but they most certainly did low ball the numbers to begin with.
* = if I recall correctly, Dodge originally rated the N-SRT4 numbers nearly identical to the SS/SC - which was a gross under rating; later they re-rated it to something like 240hp... but hey, I'm no Dodge expert.
I seem to recall reading here in the past suggestions that GM should have rated the SS/SC at something more akin to 225hp - but as you pointed out, the dyno numbers might be a smidge on the "happy" side of things;
I think that as long as before & after dynos are don on the same machine, wit hthe same settings, the OP should have a good measure on his results...
Old 04-11-2011 | 12:57 PM
Staged07SS's Avatar
Administrator
Administrator
Ronn;
The 2003 Neon SRT-4's were rated at 215 Bhp
The 2004's were rated at 230 Bhp 250 TQ. Essentially they added Mopar Stage 1 to the 2004's from the factory.
The SS/SC's if rated correctly should have been around 230 Bhp 210 TQ given their average whp.
This.
Old 04-11-2011 | 01:20 PM
nizzle's Avatar
Originally Posted by nizzle
What a lot of people dont realize is GM UNDER RATED the ecotec sc. This has been standard practice for GM and other american car companies for many years. On a stock ecotec sc, I have never personally seen one dyno under 207 whp. Most I've seen are around 213 - 217 whp. I been at the dyno and seen 2 stock 2.0 S/C IRL's dyno 230 whp +.
yep, all of you are correct and reposting this
01-12-2016 12:01 AM
10-13-2015 09:32 PM
maliki778
10-01-2015 07:39 PM
SSLOW06
10-01-2015 07:21 PM
metroplex
09-27-2015 07:48 AM
Quick Reply: D Rob's 1st Dyno Stock. Numbers inside.
