Lsj + mp90 dynoed!
#401
Even though people may run their TVS or M62 past its "efficiency" range, those blowers outside of their efficiency ranges, are still more efficient then the MP90 in the heart of its efficiency range. The MP90 on your car is a Gen 4 design which is less efficient and takes more power to spin then the M62 and much less efficient then the TVS.
pretty sure steve isnt using the old gen4 roots
#402
How much?
Okay. Hold the timing and rev to 7400 then. Deal?
How much?
#404
lol... i havnt done any tuning since the last dyno.
replacing the front two wheel bearing hub assemblies.. then save a little money for 100 oct to tune maf off meth... then save for the dyno...
need some time...
need some time...
#405
Manufacturer of Supercharger kits, remanufactured superchargers and supplier of supercharger oil.
Unless you know something I don't?
I am not knocking you either. You know that right?
#407
How much what? Power? I'd have to look at his timing map to see. Ideally I like to tune for about an 11.6-11.8 AFR and run a safe 21* of timing on the street with meth. I have experimented and 25* is attainable as well, but I would reserve that for the track or special occassions. I'd be willing to bet on the same dyno he makes ~300whp doing what I've said.
#408
Not from where Steve got his from.
#412
picked up 10 gallons worth of methanol today
had about 1 1/4 gallons left of 50/50 mix left in the tank... filled the rest of the tank up w/ pure methanol...
no bog... engagement is 8 and 14 psi
noticeable difference in pull vs the 50.50 mix
still using 19gph
12.2-12.4 afr
92,190 miles on the car... oil separator is still showing no signs of getting dirty after a full nights worth of wot driving thru the cyns.
still using 19gph
12.2-12.4 afr
#415
#416
^^^^ that wouldnt be a bad idea!
ralli -
i havnt... i did a lot of maintenance in the last 2-3 weeks. Just did my tax return last night... should be back on the rollers soon as the direct deposit hits.
ralli -
#419
#421
Those of u familiar with gcyl in hptuners. Gcyl is holding 1.12-1.20 until 4600 rpm now vs the 3800 rpm on the jbp header. Maf hasn't been touched... only things I changed are the meth mix to 100% and to a short v2 hdr.
Now hopefully the 3in dp and 3in. CAtback extend it out past 5k rpm.
#423
