Lsj + mp90 dynoed!
#503
Compression isn't so hard to change. I <3 high piston speeds and extra weight. Oh wait no I don't.
And no I never throw serious insults at chebby motors, I know full well they aren't bad, and the LS is definitely one of the finest modern engines in the fields of power production, power density, and reliability.
#504
hehehhehe well played. i'd say my ls3 revs pretty high with plenty of cubes and compression soo alls good on my end. However, older stangs are pretty cheap...and for the same money I would be making alot more power. Always a toss up. Long as it makes power. I just love making fun of other cars haha.
#505
I cant say anything about piston speeds though...i only know LSX numbers, none of the GenI SBC numbers or SBF stuff.
and hey, if you're changing compression ratio on your ford, why cant we change rod length? assuming thats even an issue
#506
extra weight? pretty sure SBC is almost exactly equal to SBF in weight...except the modern ones. Modern SBC are a lot lighter than modern SBFs since ford uses OHC now.
#507
oh, you speak seriously about teh womenz roughly 17% of the time as well.
I did a little research as well.. it depends on what year/PN 350. apparently theres some decent weight differences throughout its life, due to varying cylinder liner thickness, 2 bolt vs 4 bolt mains, etc.
#508
I can only say that the car things I truly take seriously have nothing to do with numbers, and if teh womenz have their contemporaries to blame... for not making sammiches. Kaschwinga!
#513
BACK ON TOPIC! When am i gonna hold pom pom's? If you crack 300 WHP ill consider cheering!
#515
#517
#518
#520
had fun roasting the tires in 2nd around 4-4500 rpm @ 10.8 afr lol
then the belt ribs went... then slip happened... then i went home
(stripped 1 rib off the stg2 belt, 2nd is on its way off)
#521
Why was i not invited? I mean i just put bilstein's on my truck and all but still! Lol! Where is your exhaust guy? Does he do trucks?
#522
i just went tuning and had unexpected belt shreddage. I havnt been anywhere near a dyno in 2 months now?
i rly wanna go to the dyno this week... thurs or friday now
exhaust guy is in oxnard; yes they do trucks
kenz muffler
kenz muffler
#523
Ill txt ya soon and get a number for them for a quote as oxnard would be a drive and i know there are truck exhaust specialist's in T.O. As i dont want it to pricey/to far as what would i do in oxnard for 2 or 3 hour's with no car? And ive had it done before, Same setup on a similar truck but only one Exit pipe and a magnaflow but this will be diff! Dual's Angled/spaced like a lightning with body line flush cut tip would be SEX! I has the stepside! And E85 Capable! in fact i filled up at 3.15 a gallon today! YEAH!
#524
ill take you for a spin soon enough
buying a spare head tomorrow
something always happens... guess 80k out of the belt aint to shabby
