Dyno Results Dyno pictures, videos and dyno results.
Lsj + mp90 dynoed!
Old 12-18-2010 | 02:52 PM
  #176
HunterKiller89's Avatar
Originally Posted by mrbelvedere
wow all these ******* experts
this is like the 6th time you've said this in some thread where physics is mentioned. you dont like physics?
Old 12-18-2010 | 02:53 PM
  #177
RooTBeeR's Avatar
long tube what?
Old 12-18-2010 | 05:29 PM
  #178
100% METH's Avatar
Old 12-18-2010 | 05:32 PM
  #179
elecblue06's Avatar
so where do you think that 3.5" maf and ls4 TB is actually gonna help? from what i recall people have run 400+ whp with stock TB and maf
Old 12-18-2010 | 05:34 PM
  #180
100% METH's Avatar
I don't mean to come off as rude, but I'll let you figure that one out for yourself.
Old 12-18-2010 | 06:37 PM
  #181
elecblue06's Avatar
no.. i was being polite.. you should explain it.. like i said .. the stock maf and TB have pushed OVER 400 WHP.. why in the world do you need something they dont use ? it really seems like your bandaid fixing alot of things man.. do it right the first time.. the maf is scalable and just about everyone that has tried the ls4 tb has said that it wasn't worth the like 5 hp it might've gained with all the issues it can create
not to mention.. changing a bunch of things at a time is really not a great way to figure out what works.. you could switch the header/ dp and tb and maf.. and not see any gains because one part doesn't work well..
and whats with your obsession with crush bent exhaust stuff
Old 12-18-2010 | 06:51 PM
  #182
100% METH's Avatar
sorry, I didn't interpret it that way
- g/cyl is pegging @ 5000 rpm in the high octane table (larger maf housing will solve that)
- Most of the high hp lsjs have blow through mafs
- 5hp is 5hp I didn't have before; only problem I see it creating is a touchy throttle and pegging the maf (both of which are covered)
- It's a spare 3" downpipe I have laying around. Not going to spend $200 on a 3" straight pipe for insignificant gains
Old 12-18-2010 | 07:42 PM
  #183
jsscriado's Avatar
I wish the people who made the thread would get a ban button to ban idiots so that they can't post on the thread anymore.
Old 12-18-2010 | 07:59 PM
  #184
mrbelvedere's Avatar
people who have made more then 400hp were turbo not sc and you make more then just 5hp with a ls4 one guy on here showed 21hp under the curve more with an ls4 the car isent that hard to drive with it either the bottom and mid you pick is also worth it
Old 12-18-2010 | 08:32 PM
  #185
this
throttle size is not as important on the charged air side. This is why the LNF uses a smaller TB than the LSJ as well, despite flowing greater CFMs
Old 12-18-2010 | 11:26 PM
  #186
blk06cbltss's Avatar
when i get the cams, valve springs, head p&p, 2.6 ill show you a nice dyno hahah. sadly the timing chain when bad so i have to build the motor ahahahah
Old 12-19-2010 | 12:32 AM
  #187
100% METH's Avatar
are you in the right thread?
Old 12-19-2010 | 12:37 AM
  #188
yes i am and im dissipointed in the mp90.
Old 12-19-2010 | 12:39 AM
  #189
100% METH's Avatar
Alright let me waste my time and money on a dyno an hour away that reads 25-30whp higher.
So when I lean out to 12.0-12.5 afr I hit 320-330 whp.... that way you won't be dissappointed
get real
Old 12-19-2010 | 12:40 AM
  #190
Area47's Avatar
Rent me! per hour
you are worrying about too many details to even get it right.
leave the stock tb on it.
change the header. your beloved "g/cyl" will drop like a rock. this will fix for need for a larger maf housing. which will **** part throttle and idle.
Old 12-19-2010 | 12:55 AM
  #191
100% METH's Avatar
tmrw...
Old 12-19-2010 | 03:34 AM
  #192
ralliartist's Avatar
eh, I like the LS4 throttle body personally. But there are so many people in this thread now and I think for the most part, everyone is split down the middle.
If you just swap that header and dp, then go redyno, I think that will clear up a lot of issues with everyone on here.
Old 12-19-2010 | 09:06 AM
  #193
chevysssc's Avatar
did you look at the tq
Old 12-19-2010 | 09:17 AM
  #194
Who cares if he's dissappointed. Obviously he didn't analyze anything on the dyno sheet.
Old 12-19-2010 | 10:50 AM
  #195
no i like it its just most people that post that stuff are retards regurgitating what they heard someone else say
Old 12-19-2010 | 11:45 AM
  #196
damien's Avatar
I'm going to point out that this 'dyno' reads ridiculously low as in sub 200whp for our cars. He's made almost 100whp more. That's a good gain imo
Old 12-19-2010 | 12:33 PM
  #197
chevysssc's Avatar
if you want more flow dont go ls4, port the stock. its better in many ways
Old 12-19-2010 | 01:44 PM
  #198
i wouldent say many ways your still sucking air through the same hole size
Old 12-19-2010 | 11:59 PM
  #199
100% METH's Avatar
couldn't get a hold of a o2 bung today...
so header install will have to wait until sometime this week.
Going to try and get a dyno in after the new year asap
Old 12-20-2010 | 05:06 AM
  #200
100% METH's Avatar
for all you haters (thank Euthanasia for the temporary donation!)
I'm gonna spend 2 hours taking this damn noodle off my car; there better be a substantial gain
Quick Reply: Lsj + mp90 dynoed!
