OFFICIAL DYNO THREAD (take 3)
#231
Um i put down 226hp yesterday with following mods, i think there is an issue, 3in exhaust, header, 60's, ported and polished head, blower, and throttle body, intake, cobra heat exchanger, supertech .5 mm oversize valves, 78lbs valvesprings, and nates 2.6 pully and meth injection...... this was on new eras dyno.... can someone tell me what the issue is?
#232
Um i put down 226hp yesterday with following mods, i think there is an issue, 3in exhaust, header, 60's, ported and polished head, blower, and throttle body, intake, cobra heat exchanger, supertech .5 mm oversize valves, 78lbs valvesprings, and nates 2.6 pully and meth injection...... this was on new eras dyno.... can someone tell me what the issue i/s?
#234
#236
thats why i went turbo w/ 10psi and dyno'd at 258.9 whp w/ a flawed tune on my 2.2. the tune has since been fixed. just waiting to get back to dyno it again and see where its at, should be over 260whp now. i wouldnt be surprised if i came close to 270whp
#239
I have stated before, until they PM me or post in this thread, it doesn't go up, I am not going to be drama filled like the drag time thread. The only way you are getting on is if you post your slip. I am not asking for anything more then that. Note I am not trying to sound like a dick but I don't ask for videos etc. I know what you should be running, roughly. So a bolt on 2.2 that makes 275hp is wrong.
updated
updated
#240
It is up to them if they want to add their info like you said.
#241
Just making sure I get my whp # in here.
Mods include:
ZZP twincharge kit
Bullseye Super 362
ZZP race intercooler (with v-band connections)
Tial 44mm waste gate
Tial Q bov
ZZP turbo exhaust manifold
External waste gate dump
ZZP 650HP fuel pump upgrade (includes 80lbs injectors)
ZZP fuel pump rewire\
ZZP boost reference
Cylinder Head:
Stock cylinder head
Stock cams
80lbs valve springs
Short block:
Stock pistons, rods, crank.
Balance delete
Cooling Mods:
ZZP electric water pump kit
ZZP oil cooler delete
ZZP single pass intake manifold
ZZP 15 row single pass heat exchanger
Suspension:
SSC lowering springs
ZZP spring blockers
ZZP tubular control arms
Much more to come!
Mods include:
ZZP twincharge kit
Bullseye Super 362
Tial Q bov
ZZP boost reference
Cylinder Head:
Stock cylinder head
Stock cams
80lbs valve springs
Short block:
Balance delete
Cooling Mods:
Suspension:
ZZP spring blockers
Much more to come!
#247
#249
I had my car dyno'ed on a Dyno Dynamics before which you have listed...now I re-did the stock dyno with a Dynojet hoping they'd be closer to what I think they should be (they may be a little high now, but oh well..it's what the dyno tells me...don't have the graph though).
125whp and 124wtq on dynojet for my 07 Cobalt LS.
Will make sure to get a graph next time I go (will have intake, header, dp, cat-back, tune).
#250
