OFFICIAL Dyno Thread (take two)
#126
I have a new rule that we should put into this...you MUST have to post your stock dyno numbers in order to post your modded ones, this is the only way to tell if your dyno reads high or not.
I say put there stock numbers in ( ) so it would be easier for ppl to check **** out, and nno more arguements. And if you didnt dyno stock then its easy to question your dyno
Just an Idea. My stock numbers were 212 whp and 203 wtq
#127
I agree
#131
^Unfortunately, that's probably true.
Most people have neither the time/interest/$$ to do baselines. And if they don't, then we all have to agree that the posted dyno #'s on this thread are just for fun. That's it.
I didn't even baseline my own car before installing Stage 2. Which is why I didn't bother posting my #'s here, because there''s no use in comparing my Dynapack results with the "overinflated" numbers of roller dynos.
But I think everyone has to admit, my "Same Day/Same Dyno" comparison with the 08 SS/T has A LOT going for it!
That's because Same Day/Same Dyno comparison testing tells no lies.
Let's try to get more of those if we can!
#133
You know Area. I don't think anyone has ever seen a dyno chart for you. We only just take your word for it, be really how can we know your not just fabricating numbers and taking advantage of our good faith?
#134
You know if it was anyone else i would agree with you but he knows to much about this damn car to be lieing. i beleive him and i wouldnt ever call bs on his part
#135
but yes area's number are correct, because look at his dyno runs then look at his trap, EXACTLY where it should be!! 290whp=109-110 trap
#136
lol
i have dyno sheets. i have a **** ton of the suckers actually. i have posted a few of em. i just grew tired of doing it. people will always challenge them regardless if god himself dynoed the car. so whats the point really?
lets take lsj's car for instance. he did 253 whp and trapped 115mph. now, my cute little 290 whp car should be faster right? wrong. highest i have trapped is 109.52.
now whats that say about dyno numbers? they are ******* useless when trying to compare two cars in different parts of the nation.
people rely way too much on dyno numbers. there is a fatal flaw to this
#137
lol
#139
#143
Rebel Turbo stage 2 Kit dyno numbers
In process of getting them posted.
Ran 321hp at 23psi Check signiture for options
We had trouble with the manuel boost controller and had to run higher boost then we wanted. We felt that if we could have ran 18psi on a cooler day instead of 95 plus degrees we would have ran closer to 350 but rerun will have to wait.
Actual dyno sheets will be posted on trifectaperformance.com with other cars.
#149
yeah, i noticed that. he had to update mine 2-3 times and it still reads 330torque or something which is wrong. on the 307whp pull i was like 290 something torque. oh well you were there for my pull for the proof plus i still have the dyno sheet
