Dyno Results Dyno pictures, videos and dyno results.
Staged07SS finally goes to the dyno!
Old 04-15-2015 | 10:10 PM
  #126
RoelSS's Avatar
Roel!! Great to hear from you, and thanks!!
Glad to see you still have the car. Keep in touch man.
I know I've MIA for a while but man, life has been keeping me busy. I will make the effort to stop by more often when possible
Old 04-15-2015 | 10:15 PM
  #127
chris88z24's Avatar
Perfect example of how to make power without destroying your car. Good work.
Old 04-16-2015 | 08:13 AM
  #128
Staged07SS's Avatar
Administrator
Administrator
Thanks man!
Old 04-16-2015 | 11:15 AM
  #129
CobaltSS 16's Avatar
staged - one of my favorite LSJs. Great work.... well balanced and nice numbers!
Old 04-16-2015 | 11:19 AM
  #130
Staged07SS's Avatar
Administrator
Administrator
Thank you good sir!
You made some great numbers yourself.
Old 04-16-2015 | 01:09 PM
  #131
Thank you good sir!
thank you sir!!
Old 06-14-2015 | 12:35 PM
  #132
Routs's Avatar
Late to the party as usual, but impressive stuff!
Old 06-15-2015 | 08:17 AM
  #133
Staged07SS's Avatar
Administrator
Administrator
Thank ya!
Old 06-15-2015 | 11:24 AM
  #134
yellowsupercharged06's Avatar
Thank you good sir!
he gets 0 credit until he gets a TVS on his car lmfao
Old 06-15-2015 | 11:36 AM
  #135
Staged07SS's Avatar
Administrator
Administrator
I have a TVS silly.
The H62 is a 3 lobe TVS blower.
BAM!!
Old 06-15-2015 | 11:37 AM
  #136
I have a TVS silly.
BAM!!
i was referring to the credit you were giving Sandro ... CobaltSS16 lmao
Old 06-15-2015 | 11:59 AM
  #137
I'll never hear the end of it huh??
Maybe one day I will
Old 06-15-2015 | 12:10 PM
  #138
Staged07SS's Avatar
Administrator
Administrator
ahhh ok....
I have the case of the Monday's I guess. Little slow today.
Just tell him he doesnt get credit until he installs that ported head and cams, lol.
Old 06-15-2015 | 12:17 PM
  #139
ahhh ok....
Old 06-15-2015 | 01:06 PM
  #140
ahhh ok....
Burn lmfao. And That's fair. It'll give me another 2-3 years then
Old 06-15-2015 | 01:19 PM
  #141
Staged07SS's Avatar
Administrator
Administrator
Old 09-21-2015 | 11:34 AM
  #142
Staged07SS's Avatar
Administrator
Administrator
Staged07SS goes to the Dyno Part II
Oh poo... 291whp 231wtq lol
Last year:
Not what I wanted, but still decent for how warm out it got. Unheard of in NEPA to be mid 70's in the morning in September. Blah. Also, should have stuck with my Sunoco 110 race gas mix. I used VP MS100 and don't feel the car was making max race gas timing. All in all I'm happy to finally see where my peak power occurs, because the dyno operator finally reved her out (7750 rpm) per my request. Decided to finally be done with worrying about power numbers until my buddy Trevor (Tjolley) said he's sending me a rare 2.92" GM test pulley. So, either some time later this fall, or next spring, I'm going back to the dyno with my old tried and true race gas mix and the smaller pulley for one last round of pulls
On a side note, I educated some guys at the dyno meet. Many came up to me after my pulls to say how impressed they were with the power my little 4 cylinder made (more impressed than me). A guy with a big Dodge Ram even said "I would never expect a car like that to be fast/powerful", lol.
Info:
- Same dyno
- Same day 1 year later
- Same time
- Similar weather conditions (10 degrees warmer though)
- Same mods with addition to a ZZP Fuel Pump Re-wire
Modifications:
- H62
- GMR Ported head
- COMP/ZZP S1 Cams (210/206 duration @ 1mm & 10.78mm/10.69mm lift, 109 LSA)
- 75# Supertech Dual Valve Springs
- GMR Stage 3 PCM (H.O.M. Engaged)
- GMR Stage 3 2.99" Pulley
- GMPP 42 lb/hr injectors
- Modified Airbox w/ Factory AC Delco Air Filter
- NGK BKR7EIX Plugs gapped @ 0.031"
- Ported Throttle Body
- GMPP Ported Extrude Honed Manifold
- ZZP 3" Offroad Downpipe
- Corsa Touring 2.5" Catback
- GMR Dual Pass Endplate
- GMR Opt. B
- OTTP Gen 4 H.E.
- ZZP Fuel Pump Re-wire
- VP MS100 Race Gas ~ 100 octane
Old 09-21-2015 | 11:40 AM
  #143
Dipped_Cobalt's Avatar
you do make power past 7k! nice!
Old 09-21-2015 | 11:41 AM
  #144
Staged07SS's Avatar
Administrator
Administrator
Yup, power peak was between 7600-7700rpm.
Old 09-21-2015 | 12:14 PM
  #145
Nice pulls staged! That is a pretty looking graph despite if you didn't hit what you were looking for. The power keeps climbing.
Also note, the new one is SAE correction... old one was STD. STD will yield slightly higher numbers on a dynojet. Ask the dyno operator to see if he can pull that graph up for you in STD correction. may give you a better comparison... though I don't know if you'll beat your last years numbers.
Old 09-21-2015 | 12:18 PM
  #146
Staged07SS's Avatar
Administrator
Administrator
Also note, the new one is SAE correction... old one was STD. STD will yield slightly higher numbers on a dynojet. Ask the dyno operator to see if he can pull that graph up for you in STD correction. may give you a better comparison... though I still don't think you'll beat your last years numbers.
Well ****... didn't even notice that. Thanks for pointing that out man.
I will give him a call.
Old 09-21-2015 | 12:24 PM
  #147
Staged07SS's Avatar
Administrator
Administrator
Gave him a buzz... My STD correction numbers were 302.64whp 240.24wtq
I can't believe I didn't notice that... Oh well, good to know. SAE are generally regarded as more accurate anyways.
Old 09-21-2015 | 12:31 PM
  #148
JapEatr's Avatar
South Central *********
nice numbers, comparing Hockeymans numbers to yours (different cams, and M62 vs H62) id say pretty solid output from the H62 versus an all out M62 screaming
Old 09-21-2015 | 12:36 PM
  #149
Staged07SS's Avatar
Administrator
Administrator
Thanks man!
Old 09-21-2015 | 12:40 PM
  #150
So we can say you got 303 now good job staged, I'm so jealous on how you keep your car so clean all the time lol
Staged07SS (09-21-2015)
