ZFR Dyno Results Finally :)
So today I went with my buddy Sean to get my ZFR set up on the dyno, the current mods that count are :
ZFR Turbo
ZZP Catted Downpipe
ZZP Full Intercooler Package
Stock Intake With K&N Filter
Stock Clutch
Stock Exhaust
Car was tuned with extreme reliability in mind by an awesome local tuner, didn't go all out with the tune so my numbers reflect that. I had the boost to ramp in slowly and it worked out well, Boost is set to 22-23 up top and timing is only up to 15 degrees.
We have a lot of room to grow, I need to figure out a solution for the stock intake tube, I tried putting the zzp intake tube on but it didn't fit and wont fit for shyt lol...Thanks ZZP , Timing and boost can be turned up to 25-26 psi which is where the zfr appears to wake up from the logs that I have done but I don't know when I will be waking it up never the less it pulls hard
A Stock SS/TC dyno'd there at 230whp/220wtrq
The Numbers were : 355whp/327wtrq
Dyno Sheet :
Dyno Video :
ZFR Turbo
ZZP Catted Downpipe
Stock Clutch
Stock Exhaust
Dyno Sheet :
Dyno Video :
Very nice man!!! I'm making 360whp with the K04+ but maxxed out and since you're on a conservative tune making what I make maxed out that's awesome! I may have to try that and shoot for one or two PSI more than you.
Correct, that is usually common with bigger turbos from what I seen, also the way its tuned commands for a bit lower torque numbers to avoid spinning out, breaking traction is no fun in higher speeds
Yeap Yeap, I can easily modify some stuff and get up to 380 maybe 400whp area
Aaron ! Buy a turbo already lol
Thank you sir I might be pushing a lil bit more power in the future but now I need it to be extremely reliable for the next month or so
It seems that a lot of people that get a bigger turbo try to max it out right away, I'd rather do it in stages if I'm going to, but reliability is a big factor for me now
And it still makes power all the way to the top and the torque doesn't drop that much at all
my results of my zfr
mods
autowerks street intercooler
autowerks lower charge pipe
clear image upper charge pipes
3 bar sensors
turboxs down pipe and exhaust 3" straight piped muffler
autowerks valve springs
zzp rotated trans mounts
tune was amazing by dave at performance auto works pulls super hard
and smooth
dyno 389hp/379 ftlbs 93 octane
mods
3 bar sensors
and smooth
My buddy Sean did, I just fine tuned the boost and timing the way I want it
mods
3 bar sensors
and smooth
mods
3 bar sensors
and smooth
Thanks man ! I'm not gonna lie I do miss the TVS lol, I miss the whine whine man !
lol damn I bet haha, Im still on stock clutch too, but so far my clutch is not complaining I don't know whats gonna happen when I turn the dial up a bit lol
mods
3 bar sensors
and smooth
mods
3 bar sensors
and smooth
I am getting 38.3 lbs./min at 22.8 psi and during some logs I playing with the boost I got 40.5 lbs./min at 24.8 psi
On another note I posted the dyno video
mods
3 bar sensors
and smooth
mods
3 bar sensors
and smooth
Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts
