*OFFICIAL* Torque App Mod's
Old 07-19-2013, 01:42 PM
cobalt_sport08's Avatar
Thanks guys
Old 07-19-2013, 02:18 PM
kcc140's Avatar
Originally Posted by 10CSSTC
This thing blows my mind. Show me where to go to get AFR, IAT, LTFT, STFT and voltage. Im lost.
Go into Realtime Information and find an empty screen(swipe left or right). Longpress anywhere on the screen, then select Add display, choose the type of display, then Add sensor. Basically the same as adding a widget to your homescreen on Android devices.
Old 07-19-2013, 03:02 PM
Originally Posted by kcc140
Go to Settings > Units and uncheck the box that reads "Use Celsius instead of Fahrenheit"
Still reads 32 F and same for Trans oil Temp
Old 07-19-2013, 04:28 PM
kcc140's Avatar
Did you enter a new PID with the settings listed in this thread? Originally, I tried to just edit the existing PID for IAT2, but that gave low readings like you are getting. Once I entered a new PID it worked fine.
Old 07-19-2013, 06:11 PM
the only PID# I see is the OP 222006
Old 07-20-2013, 01:38 PM
paddock's Avatar
I've been looking around, but can't find one....
Does anyone sell an OBD blue tooth unit that allows you to plug the blue tooth unit in and have a "back door" to plug in the Interceptor???
Any help or links would be appreciated...
Old 07-20-2013, 01:42 PM
06cobaltncng's Avatar
my adapter wont be here til Thursday:-(
Old 07-20-2013, 04:33 PM
serega12's Avatar
I use the whole set up, but I'm also using a "RacingMeter for Torque" app (available from the market also)... way better GUI IMO...
(This was taken right after a 1/4 mile run, that's why the temp is so high and the AVG MPG is so low... lol.)
Old 07-20-2013, 04:39 PM
serega12's Avatar
not per say like the way you describe it, but they do sell OBD II splitters...
https://www.google.com/search?q=obd+...hrome&ie=UTF-8
Old 07-24-2013, 10:33 AM
10CSSTC's Avatar
Got my adapter and have been monitoring things i have no clue about. Question is, how do i monitor oil pressure?
Old 07-24-2013, 10:43 AM
  #36
Got Brakes?
Sox-Fan's Avatar
You don't. There isn't an oil pressure sending unit in your block.
Old 07-24-2013, 10:46 AM
  #37
10CSSTC's Avatar
Well that makes as much sense as a black guy supporting Zimmerman. So it the oil pump fail, you won't know until you seize?
Old 07-24-2013, 10:51 AM
  #38
Got Brakes?
Sox-Fan's Avatar
As with most cars, there is an indicator light sender. It's on/off. It doesn't return a pressure reading.
Old 07-24-2013, 10:54 AM
  #39
10CSSTC's Avatar
Horrible design
Old 07-24-2013, 11:04 AM
  #40
Got Brakes?
Sox-Fan's Avatar
You got what you paid for.
Old 07-24-2013, 11:53 AM
  #41
just got my adapter! any extra codes I need to put in the torque app aside from the onesnit comes with? 06 lsj motor
Old 07-25-2013, 11:44 AM
  #42
10CSSTC's Avatar
Here's my setup. Is it just me it isn't that a lot of advance?
Old 07-25-2013, 06:36 PM
  #43
sLAsh's Avatar
Anyone get kr to work in a lsj? I put all three options in but none show any knock. Unfortunately no way to tell if there isn't any knock or if it's just not reading it.
I put in the plug in "knock detector" and it showed two possible incidents of when I put it in 4th and accelerated full throttle from 25 km/hr. Maybe someone who has an interceptor can see if the plug in is detecting true knock and we can get the pid from it.
Old 07-26-2013, 01:55 PM
  #44
cobythecobalt's Avatar
Would this work on a stock LT or is it more so something for people with boosted cars?
Old 07-26-2013, 02:08 PM
  #45
Fearedbynone's Avatar
i might be wrong, but I do not think this app is cobalt or even chevy specific. it should work on any obd2 car.
Dave
Old 07-26-2013, 02:44 PM
  #46
isnt that a high ltft? I thought it was suppose to stay near even.
Old 07-26-2013, 06:35 PM
  #47
sLAsh's Avatar
Mine is around the same for timing advance
Old 07-27-2013, 11:09 PM
  #48
I can't seem to find this app for iPhones. It's not in the App Store and I can't download it from the link provided. Anyone able to?
Old 07-29-2013, 11:15 AM
  #49
emiller's Avatar
Been awhile since I checked my timing but I remember it being up there.
Old 07-30-2013, 04:32 PM
  #50
10CSSTC's Avatar
Thats because apple is communist and they dont have this app.
Quick Reply: *OFFICIAL* Torque App Mod's
