*OFFICIAL* Torque App Mod's
Go into Realtime Information and find an empty screen(swipe left or right). Longpress anywhere on the screen, then select Add display, choose the type of display, then Add sensor. Basically the same as adding a widget to your homescreen on Android devices.
Did you enter a new PID with the settings listed in this thread? Originally, I tried to just edit the existing PID for IAT2, but that gave low readings like you are getting. Once I entered a new PID it worked fine.
I've been looking around, but can't find one....
Does anyone sell an OBD blue tooth unit that allows you to plug the blue tooth unit in and have a "back door" to plug in the Interceptor???
Any help or links would be appreciated...
https://www.google.com/search?q=obd+...hrome&ie=UTF-8
#37
#43
Anyone get kr to work in a lsj? I put all three options in but none show any knock. Unfortunately no way to tell if there isn't any knock or if it's just not reading it.
I put in the plug in "knock detector" and it showed two possible incidents of when I put it in 4th and accelerated full throttle from 25 km/hr. Maybe someone who has an interceptor can see if the plug in is detecting true knock and we can get the pid from it.
#50
