13w7 in the cobalt
no offense but i can almost guarantee those don't sound as good as a w7. louder hell yes but from what ive seen on the net and looking at the specs they probably dont sound bad but i probably wouldn't call them good. ive never had the chance to play with them in person thou
Spg’s oval size is made that way to get the optimum sound output and sound quality... with its 3.5 inch voice coil and over 4 inches of excursion it can drop way lower than any 15’s could.... also look at its performance... How much does a W7 13 weight? Spg 27lbs, uses neodymium magnets which are way stronger than any ferrite magnets could ever be.... Also my Amps, sub and box, and panels are for sale, im building something different for the shop hit it up if your intrestred.
Spgs oval size is made that way to get the optimum sound output and sound quality... with its 3.5 inch voice coil and over 4 inches of excursion it can drop way lower than any 15s could.... also look at its performance... How much does a W7 13 weight? Spg 27lbs, uses neodymium magnets which are way stronger than any ferrite magnets could ever be.... Also my Amps, sub and box, and panels are for sale, im building something different for the shop hit it up if your intrestred.
and damn i didnt know it used neodymium thats pretty bad ass wuts the RMS on it agn?
Rockford t1500 (1300 at 2 ohm for mine) but im selling my **** cause I want to keep all Boston Product, and their new amp is 1400 watts which will let my baby breathe
idk... we did 4 xxx in a s10 it was way louder but the spg is so hard to describe, i haven't heard anything that comes close
spg55 fits better in the balt. its like an oversized 6x9 lol. re xxx are nice.. you know the 13w7 has gone down in price you can pick up a used one for 400.. the spg55 is about the same price. on the weight of the w7.. oh gawd its heavy 52lbs. then the enclosure.. the lightest sealed enclosure i can find is like 25 pounds (mdf) so yeah you are talking about 75 pounds in the trunk not counting the amp. the amp has to be close to 15lbs. so you are pretty close to 100 pounds with wiring 0/1 gauge and caps if you go that route. ouch my 1/4 mile is dieing. damn whatever happened to orbis audio subs
spg is better in any application... if you haven't delt with one you cannot assume... and oby the way... spg SEALED BOX IS 1ft^3 sound quality port 2.1ft^3 and high out put 2.6ft^3
Im not just saying it because that what I have, from all the systems that we do and all the product we deal with this is by far the best sub... and something that is comparable to it would be a high high end dynaudio or focal and those are not even close to be in the same price range, Boston has way less invested into the product thus they can sell it much cheaper
fyi my system plays the lowest note in jeezy put on. and loudly at that
with stg2 and 2.9 pulley id be lucky to keep up with a stock ss/sc
#38
new or old XXX? and why would you put 4 in an s10?
I couldn't tell you which ones they were... He wanted 4 XXX 15's and didn't care about the bed of his truck being used up sooo we filled the whole thing up.
And yeah about your weight Emp. We did 3 Rockford T2 15's, 3 Rockford Big Power amps, 5 Batts, HO Alternator, and 5 sets of Eclipse Components, and others... That car is Slow as fuckkkk. Hyundai Tiburon.
