2 ohm-4 ohm
2 ohm-4 ohm
About to replace my stock speakers with aftermarket Pioneers. Looked at the label on the rears and it says 2 ohm. Aftermarkets are 4 ohm. Is that a problem?
Sorry, I don't know much about car stereos.
No it is not. The only difference is that your volume probably won't be as loud with the 4ohm'ers as when resistance increases overall sound output decreases.
yes the stock amp runs everything at 2 ohm. fronts tweets rears and sub. a 4 ohm speaker will get at best half power. turning ur 25w rms to a whopping 12w rms
If you don't listen to it loud then ur fine but if you want any volume then ur gonna need to swap something else... aftermarket amp and stock amp bypass or aftermarket hu and stock amp bypass
oh and if you bough the TS line of pioneers then i would recommend throwing them away and saving urself the time and hassle. they are shittier then stock by far
This is what I have attached to factory head and sounds very very nice.
Factory head, Infinity Kappa 62.9i 6.5" and 1031t front speakers, Kappa 692.9i 6x9 rear speaker, Two Alpine Type R subs in custom enclosure, Sony XM-1S mono amp
Here are the specs for the 62.9i
Features:
Infinity Kappa 62.9i 6-1/2" Kappa Series 2-way Speakers
Power Handling:
Peak: 450 watts per pair / 225 watts each
RMS: 150 watts per pair / 75 watts each
2 Ohm Impedance
Plus One Woven Glass Fiber Woofer Cone
Hi-Roll Rubber Surround
1" Rotating UniPivot
Edge Driven M.M.D. Dome Tweeter
Computer-Optimized Outboard Crossover with Tweeter Level Control
Direct-Connect Crossover Dongle
Frequency Response: 45-25,000 Hz
Sensitivity: 95 dB
Top-Mount Depth: 2-5/16"
Features:
Power Handling:
2 Ohm Impedance
Sensitivity: 95 dB
good setup. upgrade that deck and get the kappa's the juice they really want and you'll be amazed even more. crystal frickin clear.
The lower the ohms, the more a speakers design plays a factor.
