2007 Audio pinouts ( UQ3 ) w/ pioneer system
I tried and tried to make the wiring diagrams I got from GM readable online , but the images I got were just to small . So here is all the pinouts in the same format as Zinners pinouts for the 05-06 .
PIN
Wire color
Circuit #
Function
(UQ3) head unit , connector 1
RD/WH
1140
BATTERY POSITIVE VOLTAGE
2-3 NOT USED
L-GN
1948
RIGHT FRONT LOW LEVEL AUDIO SIGNAL ( - )
L-GN/WH
512
RIGHT FRONT LOW LEVEL AUDIO SIGNAL ( + )
D-GN
1947
LEFT FRONT LOW LEVEL AUDIO SIGNAL ( - )
TN
511
LEFT FRONT LOW LEVEL AUDIO SIGNAL ( + )
BK/WH
1051
GROUND
D-GN
5060
LOW SPEED GMLAN SERIAL DATA
10 NOT USED
D-BU
1796
STEERING WHEEL CONTROL SIGNAL
(UQ3) HEAD UNIT CONNECTOR 2
BN/WH
367
LEFT AUDIO SIGNAL ( + ) (BLANK IF NO XM OPTION)
D-GN/WH
368
RIGHT AUDIO SIGNAL ( + ) (BLANK IF NO XM OPTION)
PK
314
RADIO ON SIGNAL ( TO AMP )
D-BU
546
RIGHT REAR LOW LEVEL AUDIO SIGNAL ( + )
TN
1946
RIGHT REAR LOW LEVEL AUDIO SIGNAL ( - )
BN/WH
599
LEFT REAR LOW LEVEL AUDIO SIGNAL ( + )
BN
1999
LEFT REAR LOW LEVEL AUDIO SIGNAL ( - )
PK/BK
2062
CELLULAR TELEPHONE VOICE SIGNAL
TN/WH
372
AUDIO COMMON ( BLANK IF NO XM OPTION )
10-13 BLANK
14
WH/BK
644
10 VOLT REFERENCE ( RADIO CONTROLS)
L-GN
1011
REMOTE RADIO CONTROL SIGNAL ( TO AMP )
OG/BK
2061
CELLULAR TELEPHONE VOICE LOW REFERENCE
ANTENNA SIGNAL
COAXIAL CABLE
AUDIO AMPLIFIER
CONNECTOR 1
D-BU/WH
346
REAR SUBWOOFER SPEAKER OUTPUT ( + )
L-GN/BK
1794
REAR SUBWOOFER SPEAKER OUTPUT( - )
D-GN
1795
L-BU/BK
315
RIGHT REAR SUBWOOFER SPEAKER OUTPUT ( + )
BK/WH
1051
GROUND
6-7 BLANK
RD/WH
640
BATTERY POSITIVE VOLTAGE ( FROM BCM )
CONNECTOR 2
A
BK/WH
1051
GROUND
YE
116
LEFT REAR SPEAKER OUTPUT ( - )
BN
199
LEFT REAR SPEAKER OUTPUT (+)
D-BU
46
RIGHT REAR SPEAKER OUTPUT (+)
L-BU/BK
115
RIGHT REAR SPEAKER OUTPUT ( - )
5-8 BLANK
D-GN
117
RIGHT FRONT SPEAKER OUTPUT (-)
L-GN
200
RIGHT FRONT SPEAKER OUTPUT (+)
TN
201
LEFT FRONT SPEAKER OUTPUT (+)
12
GY
118
LEFT FRONT SPEAKER OUTPUT (-)
CONNECTOR 3
BN
1999
LEFT REAR LOW LEVEL AUDIO SIGNAL (-)
TN
1946
RIGHT REAR LOW LEVEL AUDIO SIGNAL (+)
BN/WH
599
LEFT REAR LOW LEVEL AUDIO SIGNAL (+)
D-BU
548
5-7 BLANK
PK
314
RADIO ON SIGNAL
L-GN/WH
512
RIGHT FRONT LOW LEVEL AUDIO SIGNAL ((+)
D-GN
1947LEFT FRONT LOE LEVEL AUDIO SIGNAL (-)
L-GN
1948
RIGHT FRONT LOW LEVEL AUDIO SIGNAL (-)
12
TN
511
LEFT FRONT LOW LEVEL AUDIO SIGNAL (+)
13-15 BLANK
L-GN
1011
I WILL HAVE THE BASE 2007 RADIO ( UQ4 ) UP TOMORROW .
All of the wires are the same as the 2005/2006 radio , they are just in different cavities in the new 2007 connectors . The one thing that IS different is the antenna . The 2007's uses a Coaxial cable , the 05-06's uses 2 14v switched wires .
PIN
Wire color
Circuit #
Function
RD/WH
1140
2-3 NOT USED
L-GN
1948
L-GN/WH
512
D-GN
1947
TN
511
BK/WH
1051
GROUND
D-GN
5060
10 NOT USED
D-BU
1796
BN/WH
367
D-GN/WH
368
PK
314
D-BU
546
TN
1946
BN/WH
599
BN
1999
PK/BK
2062
TN/WH
372
10-13 BLANK
14
WH/BK
644
L-GN
1011
OG/BK
2061
ANTENNA SIGNAL
COAXIAL CABLE
AUDIO AMPLIFIER
CONNECTOR 1
D-BU/WH
346
L-GN/BK
1794
D-GN
1795
L-BU/BK
315
BK/WH
1051
GROUND
6-7 BLANK
RD/WH
640
CONNECTOR 2
A
BK/WH
1051
GROUND
YE
116
BN
199
D-BU
46
L-BU/BK
115
5-8 BLANK
D-GN
117
L-GN
200
TN
201
12
GY
118
CONNECTOR 3
BN
1999
TN
1946
BN/WH
599
D-BU
548
5-7 BLANK
PK
314
RADIO ON SIGNAL
L-GN/WH
512
D-GN
L-GN
1948
12
TN
511
13-15 BLANK
L-GN
1011
I thought i should add this image here. It's the back of the factory deck in a 2007 Cobalt SS/SC with the Pioneer system.
In the left plug, the pins are labelled 1 (top) & 8 (bottom) for the far left, and 2-7 (left to right) for the remaining top row, and 8-14 (left to right) for the remaining bottom row.
In the right plug, the top row is labelled 1-8 (l to r) for the top, and 9-16 (l to r) for the bottom.
So if you are looking for a wire harness, get one that looks like this!
Old post:
great info... and perfect timing too...
thanks
Old post:
thanks
Boy that is pretty awesome.
Whats the address for GM readable online ?
Anyone know where I can find connectors for the head unit. Pretty much what I wanna do is extend the current HU connectors, so I can easily splice into the wires.
microELVIS- heres the pinouts for the XM reciever that u needed .
BN/WH
367
LEFT AUDIO SIGNAL (+)(TO RADIO )
D-GN/WH
368
RIGHT AUDIO SIGNAL (+) (TO RADIO )
4 NOT USED
D-GN
5060
6-8 NOT USED
BK
751
GROUND ( SEE GROUND DISTRIBUTION SKEMATIC )
TN/WH
372
AUDIO COMMON ( TO RADIO )
BARE
814
DRAIN WIRE
12-15 NOT USED
RD/WH
1340
BATTERY POSITIVE VOLTAGE ( TO UNDERHOOD FUSE BLOCK )
ANTENNA
COAXIAL CABLE
BN/WH
367
D-GN/WH
368
4 NOT USED
D-GN
5060
6-8 NOT USED
BK
751
TN/WH
372
BARE
814
DRAIN WIRE
12-15 NOT USED
RD/WH
1340
ANTENNA
COAXIAL CABLE
Originally Posted by SS_SC_Cobalt
what do we need to add XM to a 06 Redline or 07 SS? the radios are XM ready right we should be able to use the screen to see the data correct?
I have the pinouts for the 05-06 XM receiver to if u need them . You need to correctly wire in the XM receiver and antenna . I wouldnt get back on here til tomorrow morning to post them though . I do believe if I remember the pinouts for the XM reciever are the same as 2007 .
Originally Posted by SilverSS/SC
Pretty sure on the XM ready . Check the part #'s at the dealer though . Pretty sure there all XM and Onstar ready , the cars without them just have blanks in the connectors . microElvis is adding factory XM to 2007 SS sedean and wanted the pinouts for the reciever .
i know nothing about electronics and car stereo....does this basically mean there is a way to hook up the 07 stock unit into where the 06 stock unit is? i NEED ipod support now! and i dont wanna have to get an ugly 1 DIN head unit
so what is needed exactly to get the xm ready receiver to pick up XM>?
Silver SS/SC, thanks man. You are one cool dude.
hey silver. I need the audio pinouts for the stock 07 radios. also, whats the best way to re-pin a wire harness? like whats tools do you use to take the pins out, and how do you go about doing it in the first place?
do you have or send me a 06 cobalt s/c with pioneer sytem communication connector beause I try to install a gm 2007 dvd player in my 06 cobalt s/c thanks my email is dragonrotc@hotmail.com or cobalt_pr@hotmail.com thanks
agentirons
10-16-2015 02:11 AM
09-28-2015 12:51 PM
