2009 USB Radio in a 2007 SS S/C
Just to let everyone know, I swapped these radios on my 08 TC and everything works as it did before. No problem with XM, Onstar or anything else. I have no idea if Bluetooth works as I don't have a Bluetooth phone nor do I know how to sync the phone anyway. The rest worked. I just needed GM to add the radio to my car and smooth sailing from there on.
For the most part, you'll find that only the ipod and non-mp3 player USB sticks will work.
Gen 1 & 2 Zune should be supported.
My wife's Sandisk Sansa e280 is supposed to be supported, but we have yet to get it to work.
Some other brand name mp3 players will work if you put them in the correct mode. For some its MTP, for others its MSC.
Heres more information on that:
http://www.dembosky.com/PDIM_VER_CD.pdf
or
https://www.cobaltss.net/forums/show....php?p=4723995
or
#39
anyone know anyhing about swapping the onstar module?
Last edited by {TEAM ADRENALINE}; 03-13-2010 at 09:13 PM. Reason: Automerged Doublepost
#40
The onstar module is just another module in the gmlan chain, like the radio, tcm, pcm, rpd, etc.
I imagine it could have your VIN put on it at the dealer. Switching the actual onstar service to your vehicle could be difficult, but then again maybe not. Think of the people who have defective onstar modules (hypothetical). When GM sends a replacement, there must be some process for switching the service over to the new module.
Hardest part would be acquiring the module itself I think.
#42
I showed up this morning and he told me the BCM did not have the part number for the radio listed, so we essentially were screwed. He said hold on, I have an idea. He took the radio out, got what he referred to as a part number off the back (although it may have been something else ?), and somehow managed to add it to the list of available radios.
Once he did that, blamo! '09 USB radio in an '07!
New Thread made
Last edited by SS-Performance-RS; 06-26-2010 at 11:51 PM. Reason: Automerged Doublepost
#44
Will this work the other way? Situation:
CaseySS87 and I are trading radios. He has an 09 SS/TC and I have a base model 08 G5. Will both of our radios work on each other's cars?
#48
While trolling the Solstice sites trying to find info on their rims (there was a set for sale locally really cheap & I wanted to find out if they'd fit) I happened across some radio threads where they had put Cobalt & HHR hu's in their rides, so I would assume that the reverse is possible.
#49
Heres how:
https://www.cobaltss.net/forums/part...retail-224901/
#50
Hi everyone! I'm new here.
I'm looking for the right radio to fit in my car and I found two part numbers corresponding to RPO UUI.
20835359 and 20963684
(the 20758187 was replaced by 20835359)
I'm not sure which on is the right one. It seem to be something with RPO RE8 which I have but I don't know what this mean. Maybe it's the nickel finish?
Anybody have an idea??
Thank you
Thank you
