2009 USB Radio in a 2007 SS S/C
#52
Even on my '09 that came with the USB stock, the volumes are slightly different between AM/FM radio, XM, USB, and the external audio jack.
#57
bumping this up...I want to put a USB radio into my 08SS (with Pioneer). Anyone know the right part number to purchase so I don't purchase a radio with internal amp and have super loud chimes and turn signals? Is the 20758187 correct?
#58
Bumping this thread..
so i got my 09 SS/TC that had a factory radio ( without USB ) i found a 2010 radio with USB on ebay for 50$, so i swapped it ( took like 5 min ) and took it to the dealer. the radio was initially locked when i turned the car on, ( the display showed " Locked and time " ). so just to try it out i plugged my iphone to see if it would do anything... other then charge, nothing happened. so i took it to the dealer to have it unlocked and they did infact unlocked it, but now the USB doesnt charge nor it recognize the any devices.
i am planning on taking it back to see if maybe they have missed something
will keep you posted.
#59
1 more bump for the new year!
have a 06 LSJ w/ XM & Pioneer sub setup. Plan on purchasing a 09 head unit and giving it a shot. i already have done the aux hardwire and am tired of the lack of abilities.
I've heard the harness is different but i have no problem splicing a harness together. No different than an aftermarket setup to me.
I've heard this will lock up with the computer. I have scanning & launch access but also have no problem going to the dealership to work the PCM out.
Will keep updated!
Will keep updated!
#61
Will keep updated!
Will keep updated!
#62
to update all of you,
went back to the dealer, they made the USB work but now the chime and the volume is soo loud.
this is due to the internal amp that is turned on. will have to go back AGAIN... to get it turned off
haha
other than that
easy swap - love the USB and iphone6
haha
other than that
#63
Okay guys, finally got it fixed and working as it should,
the tech let me inside while he was troubleshooting and explained everything to me.
the problem was not with the amplifier but with the software that was loaded onto the radio.
you see, the are simply 2 kind of radios. one w/ usb and one wo/ usb.
but depending on the submodel of your car ss/tc ss/sc ss lt ls etc. the radio has a different software loaded.
this being said, what i did i took the VIN of another 2009cobalt that had the stock radio w/usb and gave it to the tech. then he looked it up and found out the software revision of that radio. he then copied it and loaded into mine. and done!
btw this has nothing to do with unlocking the radio. you still need the vin of the stock car that had the radio.
hope this helps all of you!!
#64
now how you know when the software was revision?
what was the model of the cobalt you took the vin from? and SS/sport/lt/ltz/basemodels?
#65
I just had a fun idea.
So you guys are looking for Cobalt SS models that had USB, you need VINs
2009 Cobalt Sedan Production Details 4_zpstmr0agij.jpg Photo by buquick | Photobucket
That is the list of Yellow SS Sedans with VINs and it shows if they had USB. So just steal their VIN and give to dealer and said that's the car it came from.
#66
if your car came with pioneer speakers i believe it should work as well pm me and ill give you the VIN
#67
I took a VIN from a 2009 SS/TC that had the Radio w/ usb from the get-co. i only took it because that particular year and submodel was exacly what i have (/w Pioneer Speakers and all)
agentirons
10-16-2015 02:11 AM
09-28-2015 12:51 PM
