6 channel amp ?
I have type r6.5 component speakers in the front
And vibe black air 6x9s in the rear
Fronts are 110 watt rms
Rears are175 watt rms 85 watt minimum
Not sure on the next pair yet but there going on the trunk lid
But I'll make sure they can handle more then 100 watts rms
That will be an expensive order man. It might be better to do two amps and spilt the duties. Just run the "trunk" speakers off your rear speakers and bridge them. That way you can over do the watts and the speakers will use them equally.
you do realize theres no minimum requirement for midrange speakers like that right? 100w is plenty but if u really want more then 100w and 6 channel... probably the only one in existence:
Leviathan III - ZED Audio
http://www.zedaudiocorp.com/index.php/order.html
I can deal with 100 watts rms at 4 ohm , just can't find n e that do so
Lol yea that's already filled up
Order Online
Order Online
How much room do you have? You could run one PBR300.2 to the trunk lid speakers and one PBR300.4 to the deck and doors. That would be plenty and all in 2 5"x1.75"x7" packages.
Lol ok
Emp would a jl Xd600/6 Be sufficient?
JL Audio CA - XD600/6
Like I said I've got 2 vibe black air 6x9s, 2 alpine type r components,
looking to get alpine type r 5.25 coaxials or something similar
