7 inch clarion... will it fit?
yes, should be no problem, but you will have to remove some metal backing behind the dash
(im assuming 7 inch is the mounting depth?) i have a double din that is like 7 and 3/8ths and i have about a 1/2 inch or so left with 5 rca cables, harness, and bus plugged in (tat i an feel, everything is pushed down tho, but works fine)
Delta coupe
09-30-2015 08:11 AM
z28addiction
09-28-2015 12:03 AM
