7 speaker full set
7 speaker full set
I have seen post about buying just the sub and maybe the amp, but is there someway to purchase the whole set with all the speakers, tweeters, sub, and amp? I was wondering because when I got my balt I wanted the system but got a sunroof instead and now i just really want the system!
btw I have an 07... if that means anything.
I Dont See Why You Couldnt Order It Later From The Dealership, But I Would Build My Own If I Were You I Have The G85 Ss/sc 06' W/ Every Option, And I Would Have Rather Not Got The System Sunroof Or G85 Pckg. For 25k Off The Showroom Floor Wasnt Worth It, But Anyway Lol Sorry But Like I Said You Should Get It From Gm I Would Think
This is what i would do if i was you.... Buy a stock sub enclosure and get an aftermarket shallow mount 10 to fit in there (a few dfferent companies make them... check out rockford fosgate and pioneer) then buy a fosgate mini amp to power said sub (the punch 300.1 should do well but check rms ratings on the sub you get). Also change out the stock speakers to soem aftermarket ones, just check around local shops and best buy type places to actually hear them. Buy whatever ones YOU think sound best (replace both the front 6.5 and rear 6X9).
After all that see how you like the system you got. If you want a lil more out of your highs or want more eq and overall system control try an aftermarket deck (you probably would get more out of the sub as well but that depends on the deck you choose). If you want alot more out of the highs get a seperate 4 channel amp.
