which adapters?
which adapters?
I was told by metra that i need the GMOS-LAN-04 and 40-GM10 and ASWI-X
I was then told I need a 40-cr10 and not the 40-gm10 for the antenna adapter from someone else and sonicelectroix.com told me I can use the ASWIPS for the steering wheel adapter instead of the ASWI-X.
Ive spent some time on here trying to get a direct answer, but im ready to order what it is i need today and I need know which adapters will work correctly so i can order them.
will this one work:
PAC SWI-X
http://www.bargainunlimited.net/serv...I-dsh-X/Detail
Thanks
will this one work:
PAC SWI-X
Thanks
Well in order to answer those questions we need more info. First what year is your car and are you rocking the pioneer system or not. Also what type of headunit are you trying to put in as that will tell which steering wheel interface will work for you.
pretty sure the swi-ps works for the 4100dvd but cant quite tell from the pics (looking for a lil 3mm plug labeled wr) and forgot from the last one i installed the swi-x should work too seeing as its universal IR but i wouldn't recommend getting one anyway. they are pretty flaky
antenna adapter is the chrylser not the gm
Electrical: How-To: Oil Pressure Install on 2006 Cobalt LS
Blackout06LS
How to Guide
38
05-13-2008 09:42 AM
