Add unlock/lock button
I have a 2007 LS, so it didn't originally come with power locks. I was desperate for a keyless entry, so the dealer installed aftermarket lock actuators and the keyless entry system for me. Now, the thing is that they didn't install buttons to lock/unlock the locks electronically. I want to put a button possibly on the dash that'll do that. The keyless entry reciever is under the driver's side dash. I don't know what kind it is, but its very small with a clear surrounding box that says "Saturn." Any ideas on how to do this would be great.
I m in the same boat as you, Ls, I added keyless entry myself. What I m thinking of doing this summer is just running a nice, factory style switch for mine. The door lock actuators on mine have two wires, I think they are just pos. and neg. so I m thinking you should be able to tye into those from each side and just wire the switch in like that.
Well, i don't really want to break into the door panels if they are difficult. Are they hard to take off? I just figured I would get to both of the actuators by splicing the wires from the keyless receiver that leads to the actuators and I just run them both to one switch and I'll put it in the center console somewhere.
The door panels are actually really easy to get off, its 3 screws and the window crank, thats it. However, you definitly could jsut splice in at the box like you re talking.
This summer I m adding power windows also, so while I ve got the door insert off to add the power window buttons, I m going to recover the insert with black and hopefully add the pwr lock switch. I m thinking I could either find the lock buttons on ebay, or out of some junkyard car. I m not worried if they look exactly the same as the factory cobalt ones, I jsut want them to look factory. Who knows, I may end up trying to find some cobalt door inserts with the switches in them, and just wire it up that way.
