aeroforce help
aeroforce help
I just put in my dual interceptors this morning and I have a question. How do I power them? I need to plug in that 3 wire setup and the red is powere and I dont know what the others go too. Where should I tap my power from and how do I do it?
ur stock boost gauge doesnt supply enough power to light them up,so run power off ur ignition...
Read this how to and it gives you a good idea about how the add-a-fuse works.
https://www.cobaltss.net/forums/show...ght=Add-A-Fuse
Why run more wire? It is easier and cleaner looking than going to the engine bay. Definately tap into the 22 slot in the interior fuse box.
alright I will add a fuse. can I put both intercepters and my a/f all together? that would be great
edit: I looked at that other link you sent me, and when he tapped into the fuse box, he used two seperate slots? is slot 22 gunna be good enough for me then?
well some time's when the car is optioned out it will power the interceptor's but not what ever the add a fuse is plugged into.. happened in my 07 RL.. i used 3m line taps and tapped into the rear cig adaptor.. powered EVERYTHING and was switched 12v.. on with the key on and kill's it when you open the door key out..
