amp keeps going into protect mode
Old 02-13-2009, 07:54 AM
nikebaseballx00's Avatar
Im gunna re-ground it tonite and let u guys know
Old 02-13-2009, 11:41 PM
well it didnt work out........
it played longer but still ended up cutting out...... i think its getting too hot, should i try keeping the gain down and turning up the bass boost? i am lost because if i keep the gain too low they barely hit
Old 02-13-2009, 11:46 PM
EmperorJJ1's Avatar
how hot is the amp getting? ur gonna need to test the impedance of those speakers eventually.
Old 02-13-2009, 11:49 PM
yea.....
emp i have a question, on mono block amps with 2 sets of terminals, they both go to the same place....
so with that being said, could i hook each sub up directly to their own terminal and it would still be the same as this diagram...
http://akamaipix.crutchfield.com/ca/...2-ohm_mono.jpg
Old 02-13-2009, 11:57 PM
EmperorJJ1's Avatar
yup.
Old 02-14-2009, 12:01 AM
so i would just run one pos and one neg from the subwoofer to one set of amp terminals
and then the same for the other subwoofer but to the other set of amp terminals
that my be my problem, i have the box terminals connected and then one box terminal going to the amp......
Old 02-14-2009, 02:31 PM
well i realized my problem....... my speaker wire wasnt tight enough to the amp terminals.
so with that being said, i think the louder i played it, the amp sensed this and would cut out
also now that they are tighter, they seem to play louder with the gain lower and the bass boost off
Old 02-14-2009, 02:40 PM
07YellowSS's Avatar
I had the same amp at one time powering my 12" kicker solo X and i ran it at 1 ohm. Never did i have a problem and the amp never even got warm, was always cool to the touch................
EDIT: My bad, i had the kac9102d
Old 02-14-2009, 02:48 PM
worst case is i will keep it for a year until the new model comes out and say theres a problem.... hopefully kenwood will ship me a new one
^^THAT IS IF AND ONLY IF IT QUITS WORKING, AS OF NOW WISH ME LUCK, NO PROBLEMS^^
Old 02-14-2009, 02:49 PM
KillinKrullin's Avatar
ohm load...... start there.
Old 02-14-2009, 02:53 PM
  #36
yea, i could have had it wire wrong since mono amps are now coming with 2 sets of terminals.....
from my understanding that is so u can connect 2 subwoofers and it connects them inside the amp instead of u having to wire them together than to the single terminal
now i got it down.......
Old 02-14-2009, 07:58 PM
  #37
stinkyfisherman's Avatar
Yea you’re right on the mono amp. I think it’s stupid to put two terminals on it, but I can’t tell the manufactures what to do so I deal with it.
Old 02-14-2009, 10:36 PM
  #38
EmperorJJ1's Avatar
i wouldnt get my hopes up on that
lol why? it makes it easier for the most part
Old 02-14-2009, 10:52 PM
  #39
lol yea, but its been playing good all night so thats wont be happening
Old 02-14-2009, 11:00 PM
  #40
EmperorJJ1's Avatar
cool just letting u know that waiting until just before ur warranty expires to get a new amp when urs isnt broken probably wont work
Old 02-14-2009, 11:04 PM
  #41
yea i know, i ment to say if i breaks
Old 02-15-2009, 04:18 AM
  #42
I like my install to look clean and the less wires I have to run/see the better.
And I just think its stupid to put what looks to be an "A" and "B" channel on a mono amp when people might not know what they are doing when they are hooking up their system and confuse them. One set of terminals makes it easy you cant really mess that up (unless you reverse polarity.)
Old 02-15-2009, 05:52 AM
  #43
Spun's Avatar
No offense but if people don't know what there doing they have no business trying to hook up an amp, and if they don't know how hook up the speaker wire to them then god help they should have it done by a pro.
IMO speaker wire twisted together at the amp= ghetto
Looks much cleaner the other way, besides, if your box holds 2 subs but they are sealed off from each other (meaning there is no way to run wire from one sub to the other) then you have to run 2 seperate wires, two terminals at the amp makes it look nice .
BTW- Every amp that I have seen, that was mono and had 2 terminals on it, told you exactly why there were 2 terminals in the owners manual.
Old 02-15-2009, 10:21 AM
  #44
None take'n. I beleve they sould take it to a pro, thats what my job is so I wanna keep it.
Old 02-15-2009, 11:41 AM
  #45
yea... i have only worked with 2 channel amps in the a past.... im only 16 but installed a good 5 systems for friends and family
this was my first mono amp and saw the 2 terminals and was like WTF, and my manual said nothing about out.... but a lil researched worked
Old 02-15-2009, 12:24 PM
  #46
It comes with time man. The more you work with something the more familiar it becomes.
If I had to count the number of cars Ive worked on i'd say up around 1500+
Old 02-15-2009, 12:28 PM
  #47
lol yea but isnt it ur job?
im just a 16 year old that helps install **** because i know a decent amount more than the friends and family
Old 02-15-2009, 05:07 PM
  #48
You are true that is my job.
16 is when I really started getting into doing install and audio.
The Rookie24
01-20-2016 05:14 PM
chefhhr
10-26-2015 10:36 PM
InfraRedline
Drag Racing
35
09-29-2015 02:09 PM
c_m_shooter
09-27-2015 04:40 PM
Dustonian131
09-23-2015 08:03 PM
Quick Reply: amp keeps going into protect mode
