amp turn on lead
amp turn on lead
i finally installed my headunit in my car and it works awesome. Sounds 50 times better than stock. The only question i have is should i install a fuse on my amp turn on lead or is that lead already fused by the accessory wire and battery wire?
Put it this way... I accidently pinched a remote wire under the seat bracket in a car I once had. The amp would stay on all the time (ground loop feeding back into the amp), and when I turned the car one, there was a nasty drone that came from the subs.
It took me about 10 minutes to figure it out, but the remote wire wasn't even warm. Like bc3tech said, there's only about .005 amps (5 mA)of juice going through that wire.
well i just want to know if it shorts out whats going to protect it? will the accessory wire fuse blow or the battery to the radio wire blow?
HOWEVER, depending on the head unit, I've heard stories where a shorted remote wire will take out the remote wire circuit of the head unit.
Ya' know what... my bad.
What I said only applies if you running the remote wire from the back of the head unit.
If you're running a remote lead off the fuse panel, it's best to jump off the terminal behind/after the fuse, or run a seperate fuse shortly after you jump off the fuse panel.
yea my remote wire is coming off my headunit, i also installed a switch with a led to turn on and off my amp whenever i want because i get sick of the bass sometimes so it's easier just to have a switch.
Does anyone know how much current a little led that comes in a switch uses?
roth
09-26-2015 12:16 PM
