Amplifier Questions
Amplifier Questions
Alright I'm pretty new to all the car audio stuff so I have a couple questions that I was hoping some more knowledgable people could help me with.
First of all I want to replace the front 2 door speakers and I was gonna put in Kicker DS60's (Any opinions on these speakers are welcome) which are 6-50W RMS speakers and I will probably leave the rear 6x9 speakers stock for now. Now the real question is about what amp I should get to power those speakers. I was looking at the Profile AP740 60Wx4 amp but will this be too much power for the speakers and how much can the stock 6x9s handle. If it is too much power what would be a better amp (needs to be less than $150).
MY last question is how do you wire the speakers to the amp? Do you have to run seperate wires to each speaker or what? This is probably the most important question since i'm completely clueless on this one.
Thanks for any help in advance and all the products I listed can be found on Crutchfields website and I can post links if needed.
pass on the Profile amp. way too much distortion coming out of that one.
the stock 6x9s are 8ohms so they're gonna have less power going to them than your fronts.
and wiring to the speakers. you just run your speaker wire from the amps to the back of the radio, all the wires are there
Thanks for the quick response. So can you recomend a different amp and is 60Wx4 to much power or will that be okay?
Id replace all your speakers before you add an amp, theres plenty of good amps for under 150, one in particular is
http://www.techronics.com/index.cfm?...roduct_ID=3885
Thanks every one for the answers but I got another question now. Basically I did a lot of searching on the techronics.com site that Xavipheus recomended and I changed my mind a lot on what I want to buy.
This is basically what I plan on getting now:
6.5" Door Speakers- Infinity Reference 6012i- http://www.techronics.com/index.cfm?...roduct_ID=2729
6x9 Read Deck Speakers- Infinity Reference 9612i- http://www.techronics.com/index.cfm?...roduct_ID=2727
4 Channel Amp for above speakers- JBL CS60.4- http://www.techronics.com/index.cfm?...roduct_ID=3948
2 10" Subs- Infinity Reference 1050W- http://www.crutchfield.com/S-6kpOQzY...520&I=1081050W
2 Channel Amp for subs- Boss Audio RT-645- http://www.techronics.com/index.cfm?...roduct_ID=3177
Alright so thats what I want to get and I just want to know what everyone thinks of this setup. I know everything is good quality but I never really heard of the manufacturer of the 2 channel amp so does anybody know anything about it?
I HATE BOSS..Garbage!!!! and for subs if you want really good sound get a class D amp
Love JBL amps..good stuff Use to run a JBL BP1200.1 Class D amp on 2 audiobahn subs
but now take that info on what you want and search ebay and get it cheaper..remember make sure to check their feedback before you order it on ebay
The main advantage of Class D amps is that they're smaller and tax the car's electrical system less than conventional amps.
EDIT: Oh yeah, and a lot of the hype about amps is BS, especially for sub amps. A cheaper name brand will sound ok, especially for subs. However, they are often way overrated (and they might not hold up as good over time). A 400 watt rms boss amp might only put out 300 watts rms, while a comparable alpine might put out more then advertised. I've been running the 12" in my old Saturn with a cheapo Pyle amp for 6 years now, and it still sounds great and hits 128 dB with regular music(small sealed box). If you want to do a system on the cheap, I wouldn't have any reservations about using a cheaper amp, just realize that you're not going to get the power advertised and the cheaper amps are usually going to be bigger in physical size.
Originally Posted by Bandit2941
Whether an amp is Class D or not does not make a difference in sound quality. Class D amps are more efficient, and they are also smaller for the same power output. Class D amps are often 80-90% or more efficient, while similar class A/B/AB amps are less then 50% efficient.
Also how much of a difference does having an amp for the 6.5s and 6x9s make cause I don't know if I'm gonna have enough money to buy the 4 ch amp right away
Originally Posted by BlackLS
Yeah thats what I thought. So do you think the Boss amp would be a good one or do you think this one would be better: http://www.crutchfield.com/S-YM7VhCt...20&I=489AP1200
A cheaper company I really like is US Acoustics. Not sure if they're even still making stuff but their stuff was always rated fairly at 12 volts (instead of 14.4 like everything else) and was priced comparably to the profile stuff you're looking at.
As far as the 4ch. Yes it will make a difference, and you'll probably eventually want one. If you can spring the cash, it'd be easiest to get it now and install it all at once, that way you don't have to rip the dash back apart to run more RCAs and such. If you don't have the cash at the moment, just set up what you can and do it later. If you do it that way though, I would run RCAs for the 4 channel as well as speaker wires for the front speakers while you're running the sub amp RCAs and remote wire........
Im running all my speakers off my deck right now and they distort really bad at high volumes, is this the fault of the deck? Im afraid to install a dedicated speaker amp if they cant handel that kind of power
