Amplifier Suggestions
Just bought this sub:
Kicker 10CVR122 CompVR 12" subwoofer with dual 2-ohm voice coils at Crutchfield.com
Any suggestions on an amp that will make it work well?
I was looking at this one
http://www.sonicelectronix.com/item_...SA-400.1x.html
that sub is dual 2 ohm....the amp you have is not one ohm stable, and will put out less power @ 4 ohms than @ 2.....unfortunately with that coil setup you have on that sub you won't be able to wire it to 2 ohms....For you situation, this very similar 2 channel amplifier would suit you just fine if you wired the subwoofer coils in series and bridged those inputs...:
PowerBass ASA400.2x (asa4002x) 800W Max, Auto Sound Series 2-
