Amps and other works
Old 03-16-2011, 11:14 AM
reign1's Avatar
found this for 116 bucks brand new
Rockford Fosgate Prime R500-1 Amplifier
Rockford Fosgate amplification at an unbelievable value, the R500-1 mono amplifier pumps out 500 watts into a 2-ohm load, perfect for a pair of 10" or 12" woofers
for a pair???
Old 03-16-2011, 11:59 PM
c4w18's Avatar
Good deal, but what website is this through? And no, not only a pair, it will work fine with your sub. Let me know what website though, some are scam artists even though they look legit.
Old 03-17-2011, 11:00 AM
reign1's Avatar
Old 03-21-2011, 11:05 AM
reign1's Avatar
my project is complete for now.
JL Audio 12W3. sealed box.
brand new Rockford Fosgate R500-1 Mono Amp.
Bass knob wired under the steering wheel
Wires.
Installation
$285 installed....
Im happy and it hits hard
Old 03-21-2011, 12:00 PM
c4w18's Avatar
nice dude glad to hear you got it up and running!
Old 03-21-2011, 12:48 PM
reign1's Avatar
they tried telling me the sub is starting to rip though. :/
idk what other sub id go with. but it hits pretty hard. and i havent pushed it either.
im prolly going to put my seat down and see how it hits that way
Old 03-21-2011, 02:43 PM
EmperorJJ1's Avatar
whats starting to rip? pics?
Old 03-21-2011, 03:29 PM
reign1's Avatar
ok ill try to explain.
theres the plastic that screws to the box. then the foam bubble looking outer ring. then the rubber on the walls if you wanna say
between the foam bubble looking outer ring and the wall of the sub. he said it looked weak. didnt look like it to me though
Old 03-21-2011, 04:15 PM
EmperorJJ1's Avatar
ah i c... so theres no holes or rips right now but whoever you talked to said it looked fatigued.
Just fyi if it starts becoming a problem and you see a small rip you can put silicone on the inside (for cosmetic reasons, you can put it on the outside instead if you want) as long as its a small portion. Its not perfect but it will hold up well over time. Just make sure if you do do it on the inside you want to let the sub dry outside of the box for at least 24 hours
Old 03-21-2011, 11:21 PM
c4w18's Avatar
yea sounds like they want to get you to buy another sub or get a recone.....if you don't see any visual deterioration don't worry about it....if it ain't broke don't fix it.
Old 03-22-2011, 11:12 AM
  #36
reign1's Avatar
just opened my trunk this morning and the box slid around. any way to mount it oranything?
Old 03-22-2011, 07:10 PM
  #37
c4w18's Avatar
L-Brackets. Pick em up at taylors, home depot, etc.
Old 03-23-2011, 10:55 AM
  #38
reign1's Avatar
ya i was thinking L brackets as well.
Old 03-23-2011, 11:05 AM
  #39
padlock's Avatar
i got a pioneer gm-5400t amp up for sale
Old 03-28-2011, 05:21 PM
  #40
reign1's Avatar
set up has been in. just mounted with the L bracket. hopefully it doesnt put soo much stree. ill post pics
Old 03-30-2011, 12:41 PM
  #41
reign1's Avatar
sometimes it feels like the sub has a split second delay after the beat. any idea?
Old 03-30-2011, 12:43 PM
  #42
Mnatvyc1223's Avatar
here... wire these up...
put me in coach!
Old 03-30-2011, 01:52 PM
  #43
reign1's Avatar
Old 03-30-2011, 01:56 PM
  #44
c4w18's Avatar
sexual. clean up that speaker wire!
Old 03-30-2011, 01:58 PM
  #45
reign1's Avatar
ill prolly just tuck the wire.
but im getting a split second lag between the beat of the song and the bass kicking in. anyone know how to fix?
Old 03-30-2011, 02:18 PM
  #46
jmesl8er's Avatar
^^^^^ yep, buy my 1000 watt phoenix gold zpa, it will solve all your problems. it will blow your **** up, then you can get brand new pretty speakers
Old 03-30-2011, 04:30 PM
  #47
c4w18's Avatar
uhhh what kind of H/U do you have? maybe there's a time delay setting?
Old 03-30-2011, 10:11 PM
  #48
EmperorJJ1's Avatar
try facing the sub backwards... it might just be the way it is. some music is just prone to that
Old 03-31-2011, 12:11 AM
  #49
c4w18's Avatar
transfer functs. ftw.
Old 03-31-2011, 12:12 AM
  #50
c4w18's Avatar
and call me retarded JJ, but i don't get your sig.
Quick Reply: Amps and other works
